How to Factor 4x^4-x^2-18: Step-by-Step Solution and Tips
  • Thread starter Thread starter mindauggas
    Factoring
The discussion focuses on the factorization of the polynomial 4x4 - x2 - 18. The correct factorization is established as (x2 + 2)(2x - 3)(2x + 3). Participants suggest various methods, including substitution (letting u = x2), grouping, and completing the square. The method of calculating the product of coefficients (a*c) to find factors that sum to the middle coefficient is highlighted as an effective strategy for factoring quadratic trinomials.
  • Understanding of polynomial factorization techniques
  • Familiarity with quadratic equations and their properties
  • Knowledge of substitution methods in algebra
  • Ability to perform operations with binomials and trinomials
  • Study the method of factoring quadratic trinomials using the a*c technique
  • Learn about completing the square for polynomial equations
  • Explore the use of substitution in simplifying polynomial expressions
  • Practice additional factorization problems involving higher-degree polynomials
Students studying algebra, educators teaching polynomial factorization, and anyone looking to improve their skills in solving quadratic equations.
mindauggas
Hello,
Factor: 4x^{4}-x^{2}-18
I solved a similar problem x^{4}-6x^{2}+9 by equating x^{2} to t and then reverse-FOIL'ing... this one just wouldn't give in...
Completing the square also does not help to get the answer (presuming of course that the answer is correct, which I wouldn't dare not to do before consulting in this forum)...
I have the answear: (x^2+2)(2x-3)(2x+3), so I need your help on the reasoning process guys.
Replace x2 by t as you did before and complete the square. Then factorize further if it is possible.
ehild
There's also another method for factoring a quadratic in the form ax2 + bx + c. Let u = x2 so that we now have 4u2 - u - 18.
  1. Calculate a*c, which is -72 for this problem.
  2. Find two factors of -72 that add up to -1.
    For this problem, 8 and -9 are factors of -72, and they add to -1.
  3. Rewrite the quadratic with the middle term expanded using the factors found in step 2.
    4u2 - u - 18 = 4u2 + 8u - 9u - 18.
  4. Factor by grouping to get the two binomial factors.
    4u2 + 8u - 9u - 18 = 4u(u + 2) - 9(u + 2) = (4u - 9)(u + 2).
Don't forget to undo the substitution...
Thank you
Can't you directly complete the square & then factor ?
4x^4 - x^2 - 18 = \left(2x^2 -\frac{1}{4}\right)^2 - \left(\frac{17}{4}\right)^2 = (2x^2 + 4)(2x^2 - 4.5)
Or (x^2+2)(4x^2-9)=(x^2+2)(2x+3)(2x-3)
ehild
This is a great method in factoring quadratic trinomials. I first learned of it in reading Lial's http://www.pearsonhighered.com/educator/product/Introductory-Algebra/9780321557131.page" book. It's interesting that when I learned factoring in school we were taught to just guess-and-check. I now teach this method to my freshmen Algebra I classes, even though their books use the guess-and-check method.
