Factoring for Higher order ODE
4 replies · 2K views · last reply
trap101
Solve the differential equation:
y(5)+12y(4)+104y(3)+408y''+564y'=0
where the (n) is the nth derivative.
So it's a 5th order DE. Now I'm trying to find the roots:
One of the roots is r = 0, which I obtain by factoring the equation into this form:
r(r4+12r3+104r2+408r+1156) = 0
No problem there. Now the other solutions are complex, my issue is how can I find those solutions from this 4th degree polynomial? I can't synthetically divide like it was just real numbers, so what do I do? The solution get's it into the form:
(r2+6r+34)2 from here I see how to get the complex, but how do I factor my above equation even to get this equation?
Besides that factoring issue I understand the problem.
Thanks
You can look up "roots of quartic" in wikipedia and use the general formula they supply or you just guess. (Or use a math program.)
Since it is a 4th order polynomial, not obviously a quadratic in r^2, you would guess something like (ar^2+br+c)^2 - expand it out and compare the coefficients.
In your characteristic polynomial, it is not clear why you have 1156 as the constant term rather than 564.
LOL, using that formula is just a cruel joke. If that's the only way of being able to solve these sorts of problems. How would they ask them on a quiz? I ask because I have a quiz tomorrow and it is mainly on higher order DE's if this is the general format to get them, how in tarnation are they going to ask me to solve any higher order DE's beyond one's with real solutions? That would be a nightmare to solve by hand.
There are almost no practical uses for that formula. If they give you a high order polynomial to solve they will have set it up to be easy enough so it will factor with some guessing.
