Falling Mass on a Pulley - Rotational Energy
9 replies · 3K views
hitspace
A frictionless pulley has the shape of a uniform solid disk of mass 2.50 kg and radius of .2 m. A 1.50 kg mass is attached to a very light wire that is wrapped around the rim of the pulley, and the system is released from rest. a) How far must the stone fall so that the pulley has 4.50 J of kinetic energy. b) What percent of the total kinetic energy does the pulley have?
KE_Rotational = (1/2)Iw^2
I_Disk = (1/2)Mr^2
v=rw
Vf^2=Vi^2 + 2gΔy
Plugging in I_Disk into KE Rotational, I had a single unknown variable, w, which I solved for and got
KE = .5 [ .5(2.5)(.2)^2 ] w^2 w = 13.41 rad/s
V= rw so V=.2(13.41) = 2.683 m/s which is the linear velocity of the falling mass connected in tandem with the pulley.
My solutions manual uses some sort of conservation of energy approach at this point. I tried using
kinematics and the formula Vf^2=Vi^2 + 2gΔy as such.
2.68^2 = 0 + 2(9.8)(y) , and Delta Y = .367 m. I'm posting because my book says this answer is wrong; it says .673m. I understand that their was a energy approach to this problem, but I'm confused why my answer is not the same despite the differing approach. I didn't see any road blocks in my way, and it's making me wonder what I didn't account for trying this with kinematics.
Any help would be appreciated.
on Phys.org
Because the disk's rotational inertia will resist the acceleration you mean? Meaning acceleration would be less but unknown... which would be the roadblock to using kinematics?
So if I did this the way of energy conservation, would it go like this?
KE_rot_i + KE_i + Ug_i = KE_rot_f + KE_f + Ug_f
4.5 joule was given at the beginning of the problem.
0 + 0 + mg(h1) = (4.5 J) + .5 (1.5) (2.683)^2 + mg (h2)
h= 1.7 m ... still doesn't match. I'm guessing I screwed up again?
If you assume that h2=0, then it looks like h1 comes out to match the book's answer . . . unless my math is wrong.
No, no, you are absolutely right... though I am confused why it only works if we assume h2 = 0.
Well, you can also solve for the delta, h1 - h2, which is how far it moved. It is just convenient to assign the final height to be 0.
It's often worth doing a mental approximation to check for finger trouble on the calculator.
2.7^2 is about 7; 7x.5x1.5 about 5; +4.5 =9.5; /g=1; /1.5=2/3=.67.
That is actually what I did previously - got 1.7 , and it turns out, it was calculator error. Thank you haruspex!
haruspex said:
It's not a roadblock. You can calculate the acceleration.
With regards to this, I would be interested in the general approach. Does it have to do with torque? I haven't yet reviewed that, but I'm starting that chapter now.
