Fast and slow speed of Fan in hot weather?
The discussion centers on the energy consumption of electric fans when operated at different speeds during hot weather. It is established that the faster setting of a fan expends significantly more energy compared to the slower setting. The higher speed requires the fan to perform more work on the airflow, resulting in increased energy usage. Participants clarify that while both settings provide cooling effects, the faster setting is less energy-efficient.
  • Understanding of basic physics principles related to work and energy.
  • Familiarity with electric fan mechanics and airflow dynamics.
  • Knowledge of energy consumption metrics in household appliances.
  • Awareness of how fan speed affects cooling efficiency.
  • Research the energy consumption of different fan models and their efficiency ratings.
  • Explore the principles of thermodynamics related to airflow and cooling.
  • Learn about energy-saving techniques for using electric fans effectively.
  • Investigate alternative cooling methods and their energy implications.
Homeowners, energy efficiency advocates, HVAC professionals, and anyone interested in optimizing cooling solutions in hot weather.
cherish
Hi all, I am wondering that we should choose fast or slow function of electric Fan in hot weather, which function will spend much more of energy?, can someone give me an explanation :D Forgive me if the questions is silly
cherish said:
Hi all, I am wondering that we should choose fast or slow function of electric Fan in hot weather, which will spend much more of energy, can someone give me an explanation :D Forgive me if the questions is silly
Movement of air it gives the sensation of coolness.
Hurry evaporation, which consumes energy, so it cools.
(When something is hot, you blow over it.:smile:)
I received an answer from another forum that:
"Regarding such as windmills are the way we think of but here it is another different. about Windmills, you eat less (less wind-> less energy), the less electricity it, eat it (much wind -> more energy), it granted more power. It is your case fans for its abundance (plants with a capacity of xxxx folding times) and eat it how much it took, slow fan on the fan then consume less but consumed on multiple inductors, fans back quickly on the fans consume more but less consumption in the inductors"...
The higher setting will use more energy. Energy defined as the integral of work. When the fan is at a higher setting, it's performing more work on the fluid flow, ergo more energy.
What exactly is your question?
Which setting will expend more energy? Definitely the faster setting.
Or are you asking a different question, such as: which setting is better to keep you cool? A lower setting that creates less waste heat?
yeah, that's my question, 'cause i saw an argument from other guys that someone says fast or slow function of fan they expend energy equally, someone says fast function expends much more energy, and they illsutrate by complex formulas of input and output energy on how it was transformed in different function of speed :confused:
On the faster setting, the fan expends more energy.
cherish said:
i saw an argument from other guys that someone says fast or slow function of fan they expend energy equally...
Tell them that's really awesome. If turning up dial of a fan does not use any more energy, then they could scale this up thousands of times to have the fan go hundreds of miles per hour (without using any more energy), then put wind turbines in front of their fan, and solve the energy crisis. :rolleyes:
Hi, thanks a lot, now it's very clearly, and very exciting answer, i'll quote your illustration and send them now ;)
  • · Replies 22 ·
