Fe2O3 Thermal Decomposition Question
Fe2O3 decomposes into Fe3O4 and O2 at approximately 1500°C, as indicated by the Ellingham diagrams. Further decomposition to iron metal requires temperatures in the range of several thousand degrees. If the sample contains a reducing agent like carbon, a redox reaction can occur at lower temperatures, likely around 1000°C. The feasibility of achieving these temperatures depends on the available equipment.
BH1988
Hi, I've been asked to heat a sample that contains Fe2O3, amongst some other things, to a temperature where Fe2O3 will decompose. I am unable to find the temperature at which I would need to heat the sample and I'm not entirely convinced this is actually possible with the equipment I have available. However, it would be greatly appreciated if anyone could provide me with this temperature and if possible a reference to go with it.
Chemistry news on Phys.org
http://web.mit.edu/2.813/www/readings/Ellingham_diagrams.pdf
The Ellingham diagrams in the above link suggest that ##Fe_2O_3## decomposes into ##Fe_3O_4## and ##O_2## at around 1500°C. Further decomposition to iron metal probably requires several thousand degrees. If "some other things" include, e.g., carbon or another reducing agent, then you can get a redox reaction to happen at a low(-ish, but still probably around 1000°C) temperature.
  • · Replies 21 ·
9K
  • · Replies 131 ·
9K
  • · Replies 26 ·
  • · Replies 17 ·
