Fermat's Little Theorem proof: multiplicative cancellation in fields
  • Level: Undergrad
  • Thread starter Thread starter Math Amateur
    Theorem
Math Amateur
MHB
I am reading Anderson and Feil - A First Course in Abstract Algebra.
I am currently focused on Ch. 8: Integral Domains and Fields ...
I need some help with an aspect of the proof of Theorem 8.7 (Fermat's Little Theorem) ...
Theorem 8.7 and its proof read as follows:
My questions regarding the above are as follows:
Question 1
In the above text from Anderson and Feil we read the following:
" ... ... Because a field has no zero divisors, each element of ##S## is non-zero ... "Can someone please demonstrate exactly why this follows ... ?
Question 2
In the above text from Anderson and Feil we read the following:" ... ... Because a field satisfies multiplicative cancellation, no two of these elements are the same .. ... "Can someone please demonstrate exactly why it follows that no two of the elements of ##S## are the same .. ... "
Help will be appreciated ...
Peter*** EDIT ***
oh dear ... can see that the answer to Question 1 is obvious ... indeed it follows from the definition of zero divisor ... apologies ... brain not in gear ...
Math Amateur said:
Question 2
It's also obvious. If we assumed ##[x\cdot n]=[x\cdot m]## then what would this mean? You can use all field operations and again the lack of zero divisors. In general, the question to be answered is: why do fields allow multiplicative cancellations? The reason doesn't require this special field, so you may as well prove: ##a\cdot m = b \cdot m \Longrightarrow a = b## for ##a,b \neq 0## of course.
Thanks for the help fresh_42 ... grateful for your help ...
If ##[ x \cdot n ] = [ x \cdot m ]## then by cancellation in a field, we have n = m which cannot be the case for the members of the set S ...
Cancellation works in fields since every element of a field has an inverse ...
... so if ##a \cdot m = b \cdot m## then we can post-multiply by ##m^{-1}## and get ##a = b## ...
Hope that's right ...
Peter
Peter
Well, partially. You cannot rule out the case ##m=0## at prior and operate with ##m^{-1}##.
Therefore wait as long as you can with additional assumptions.
This is more of a general advice. Instead operate without (multiplicative) inverse elements.
