Fermionic Operators & Anticommutation: All You Need to Know
  • Context: Graduate
  • Thread starter Thread starter gonadas91
    Operators
The discussion revolves around the properties and implications of fermionic operators, particularly focusing on their anticommutation relations in the context of a Hamiltonian involving two subsystems represented by left and right wires. Participants explore the implications of these relations on the diagonalization of the Hamiltonian and the treatment of interaction terms.
  • One participant questions whether fermionic operators acting on different subsystems commute, proposing that they might due to isolation.
  • Another participant suggests that anticommutation relations are necessary when the subsystems interact, indicating a dependency on the system's state.
  • A participant presents a Hamiltonian that includes terms for both left and right fermionic operators, raising concerns about the implications of anticommutation at the interaction point.
  • There is a discussion about diagonalizing the Hamiltonian and the challenges faced when trying to transform the operators into a new basis.
  • Some participants mention the use of a Bogoliubov transformation, debating its applicability to fermionic operators and the preservation of anticommutation relations through linear transformations.
  • Concerns are raised about the complexity of combining multiple operators from different subsystems to achieve diagonalization of the Hamiltonian.
Participants express differing views on the treatment of fermionic operators in the context of their isolation and interaction. There is no consensus on the best approach to diagonalize the Hamiltonian or the applicability of certain transformations.
Participants note the complexity of the Hamiltonian structure, including the presence of interaction terms and the challenges in transforming operators while maintaining the required anticommutation relations. The discussion reflects uncertainty regarding the mathematical steps involved in diagonalization.
gonadas91
Hi ! I have a doubt about fermionic operators with the anticommutation relations. I know they follow anticommutation, that is,
\begin{eqnarray}
\lbrace c_{i}^{\dagger},c_{j}\rbrace=\delta_{i,j}
\end{eqnarray}
That is for fermionic operators. But, suppose I have two different kind of fermionic operators, i.e, one refers to the left "wire" of a system, and the other to the right "wire".
\begin{eqnarray}
c_{i, L}^{\dagger} c_{j,R}^{\dagger}
\end{eqnarray}
Here, L denotes that this fermionic operator act on the left wire of a system, while R means the right wire.
My question is, do this operators COMMUTE? I mean, because they are acting on different parts of a system (like a subsystem), do they commute? Iam getting confuse about it! The thing is, can I do this?
\begin{eqnarray}
[ c_{i,L}^{\dagger},c_{j,R}]=0
\end{eqnarray}
As long as the systems are completely isolated from each other, it doesn't matter whether you assume commutation or anti-commutation relations. However, whenever the electrons from the left and right subsystem interact with each other, it is important to use anti-commutation relations.
That is the thing, that I have a hamiltonian of the type:
\begin{eqnarray}
H=\sum_{i} e_{L,i}c_{i,L}^{\dagger}c_{i,L} + e_{i,R}c_{i,R}^{\dagger}c_{i,R} - t(c_{L,0}^{\dagger}c_{R,0} + c_{R,0}^{\dagger}c_{L,0} + h.c)
\end{eqnarray}
where h.c means complex conjugate. If I use anticommutation at point x=0 for the two creation and annihilation operators, that is, with the " -t" term, this part is null. Any ideas?
What do you want to calculate?
The idea is to diagonalise this part of the Hamiltonian, so I tried to do a change of basis for new fermionic operators, when it becomes diagonal, and I failed. The thing is that having diagonalised this part, then I want to treat interaction terms using Green´s function. However, because couldn´t diagonalise it first, I just calculate the interaction Green function supposing that the "t" term is my interaction, and having the rest as Ho. However, the calculated Green function diverges when I try to integrate it in time, because I only got two non interacting Green functions, and time dependence cancels out. Because of that, I think the "t" term can´t be treated as an interaction, and there should be one way to diagonalise the hamiltonian of the expression above all together
I can't see any reason, why your hamiltonian should not be diagonalizable. What transformation did you try?
If the particles are in different wires should they not be treated as distinguishable? Is wave function overlap the same as interaction? I don't think so so, but I stand to be corrected.
For i=0 you obviously have some interaction of L and R in the hamiltonian.
You can write this in matrix form ## (c_{L0}^\dagger, c_{R0}^\dagger) \begin{pmatrix}e_{L0}&-t \\ -t &e_{R0} \end{pmatrix} (c_{L0}, c_{R0})^T##. If you call the matrix in the center H which is diagonalized by the unitary matrix V, i.e. ##H=VV^\dagger H V^\dagger V##, then V obiously also transforms the creation and anihilation operators as ##V(c_{L0}, c_{R0})^T##.
Yes, to concrete, the equivalent problem in 1D corresponds with a Dirac delta function at x=0, so obtaining the eigenfunctions is something that can be easily done for one particle. Thus, I will write the hamiltonian in the following way
\begin{eqnarray}
H=\sum_{k1}{e_{k1,L}c_{k1,L}^{\dagger}c_{k1,L}} + \sum_{k2}{e_{k2,R}c_{k2,R}^{\dagger}c_{k2,R}} - t\sum_{k1,k2}T_{k1,k2} (c_{k1,L}^{\dagger}c_{k2,R} + c_{k2,R}^{\dagger}c_{k1,L} )
\end{eqnarray}
Here T_{k1}{k2} is the transmission coefficient calculated with the continuity conditions. What I would like to do now is to find a transformation to diagonalize this hamiltonian, but it seems to be non trivial ...Ideas?
Sorry I forgot to say that I changed to momentum basis. Also, consider the hamiltonian as this because, at the beginning of the post, I think I add more terms in the "t" hopping. That is, the idea is that the wires are only "separated" at x=0, which implies a delta function, but it exists some probability of hopping from the left side to the right side and viceversa. That`s what the second term means.
I understand your hamiltonian. But as in my former post you just have to diagonalize a matrix with the e's on the diagonal and terms -tT on outer diagonal positions. You probably have to do this numerically in the general case, but the unitary matrix which diagonalizes this matrix will also transform from the old to new creation operators.
I will try some transformation between the operators and I will see. Thanks!
Ok, coming back to the topic, I have tried several transformations between the creation and destruction operators and I got nothing. I understand what you say. in this case, the hamiltonian, as it appears above, is just the product of a "row vector" that contains the creation and destruction operator, by a matrix, times a "column vector" that contains also the creation and destruction operators, but it is the transposed conjugate of the row vector. The thing is that, if I do it (it is a 4x4 matrix) I get the eigenvalues andeigenvectors with Mathematica... But the thing is that thesenew creation and destruction operators (new basis) depend on the others, the ones which form the previous basis. But, because these new operators are also fermionic operators, they must satisfy anticommutation relations, and with this transformation it seems that they don´t. Actually, mathematica gives me, for the new creator operator, a linear combination of the previous creation operators... But this can be understood as a Bogoliubov transformation for the new operators.
But Bogoliubov transformation can´t be applied to fermionic operators... So the problem is still there!
Yes, you can view this as a Bogoliubov transformation, although it doesn't mix creation and anihilation operators with each other. I don't quite understand why you say that Bogoliubov's method isn't applicable to fermionic operators. In fact, the classical example of the B transfomation occurs in the theory of superconductivity where it is applied to describe the fermionic excitations in a superconductor.
As you correctly observed, the new operators are linear combinations of the old ones and linear unitary transformations preserve the anti-commutation relations: Let ##b_i=V_{ij}c_j## and ##b^\dagger_k=c^\dagger_l V^\dagger_{lk}## (summation over equal indices is understood), then ##\{b^\dagger_k, b_i\}=b^\dagger_k b_i+b_i b^\dagger_k=V_{ij}V^\dagger_{lk}\{c^\dagger_l,c_j\}=V_{ij}V^\dagger_{lk}\delta_{jl}=(VV^\dagger)_{ik}=\delta_{ik}##. In the last step, we use that V is unitary.
Yes but the thing is that I have 4 different operators... Two correspond to the left side (left wire) and the other two correspond to the right side, and I don't know how to combine them to diagonalize the hamiltonian.. As you can see, they are crossed in the second term, and also, there is a double summation
Doesn't look so complicated. E.g. you could use for the left vector: ##(\ldots c^\dagger_{kL}c^\dagger_{kR}\ldots)## and accordingly for the right one ##(\ldots c_{kL}c_{kR}\ldots)^T##.
Then the matrix H in the middle has 2x2 blocks on the diagonal (i.e. for ##k_1=k_2=k##) ##\begin{pmatrix}e_{kL}&-tT_{kk}\\-tT_{kk}&e_{kR}\end{pmatrix} ## and away from the diagonal ##\begin{pmatrix}0&-tT_{k_1k_2}\\-tT_{k_1k_2}&0\end{pmatrix} ##.
Ok I am trying to do it, but you mean that the H matrix (which I just want to diagonalize) is a 4x4 matrix, and the basis will be the creation operators?
It is just because I don understand so well what you mean by away from the diagonal, since the H is not a 2x2 matrix... The second block in the diagonal would be the same as the one you post?
No, I wanted to say that the matrix is a 2Kx2K matrix with K being the number of k values. I did chose an ordering so that the creation or anihilation operators with the same k but different index L or R are adjacent in the vectors. Hence the full matrix is made up from 2x2 blocks labeled by k1 and k2.
  • · Replies 0 ·
  • · Replies 24 ·
