Ferris Wheel question (Motion in 2d)
8 replies · 6K views
jmedina94
1. The Ferris wheel [...] rotates counterclockwise, is just starting up. At a given instant, a passenger on the rim of the wheel and passing through the lowest point of his circular motion is moving at 3.00 m/s and is gaining speed at a rate of 0.500 m/s^2 .
2. Find the direction of the passenger's acceleration at this instant.
3. My attempt was using: the arctan 0.64/0.5, and that yielded ~52.0° but no dice so, could someone help me?
Show how you made your calculation. (Some information is missing from your problem statement.)
The problem: The Ferris wheel in the figure (Figure 1) , which rotates counterclockwise, is just starting up. At a given instant, a passenger on the rim of the wheel and passing through the lowest point of his circular motion is moving at 3.00 m/s and is gaining speed at a rate of 0.500 m/s^2 .
The ferris wheel's radius is 14m**** Sorry about that!
Centripetal Acc = v^2/r
= 9/14 m/s^2 = 0.64
Tangential Acc = 0.5 m/s^2
Magnitude of both vectors = 0.81 m/s
θ = tan^-1 (0.64/0.5) *this was wrong*"find the direction of the passenger's acceleration at this instant"
Ah, good.
= 9/14 m/2^2 = 0.64
OK, but with respect to what is that angle? How do they want the direction represented?
Not sure I was just testing out a method I had already practiced, probably the center of the ferris wheel?
They want it as:
θ= __° north of east
The passenger is at the bottom. Draw a picture of the acceleration vector.
They want it as:
You are on the right track, you just have to express it correctly.
This is my rendition of the question, not sure if it's the correct way to solve the direction
What I have in mind is this: Put a dot where the passenger is. Then draw the vectors representing the tangential and centripetal acceleration of the passenger. Then draw their sum and see where it points.
Technically, I think you mean tangential and radial acceleration, though in this case, since r is constant, radial and centripetal will be the same, just opposite sign.
