FET common source analysis with source resistor
8 replies · 5K views · last reply
naman chauhan
Hi everyone,
Hand-drawn FET common-source amplifier circuit with drain resistor RD, source resistor RS, gate resistor RG, and an AC source, followed by its small-signal equivalent using gm Vgs, rd, RD and RS, with handwritten formulas for Zin, Av and Zo.
I have attached an image of fet amplifier in common source configuration. I want to have the ac analysis of this circuit. I am able to figure out the input impedance and the voltage gain. But I can't formulate for output impedance.
According to me, while calculating output impedance input should be zero. As soon as vs becomes zero the value of current (gm Vgs) will be zero. So the current source will behave as an open circuit. And we get (Rd||rd). But according to book it's wrong.
Can anybody help!
Thanks in advance.
Can you tell me what is a rd resistance. rd should not be connected between drain and source (parallel to the gm*Vgs current source) ?
http://forum.allaboutcircuits.com/showthread.php?p=208154#post208154
well rd is the resistanace offered by FET. Its the internal resistance of the device. It is inverse of the trannsconductance offered by FET.
rd= 1/gm
rd= 1/gm
No, that completely wrong. rd = ro = ΔVds/ΔId at constant Vgs - is a small-signal internal resistance parallel to the gm*Vgs current source. But not equal to 1/gm.
So you need to use this small-signal model to find output impedance.
Small-signal equivalent circuit of a common-source FET stage: a current source g_m v_GS in parallel with r_O, with R_D at the top and R_S at the bottom; a test voltage v_X drives current i_X into the output node.
Zo = Vx/Ix
  • Small-signal equivalent circuit of a common-source FET stage with resistor RD at the top, resistor RS at the bottom, a current source gm vGS and resistor ro in parallel, and a test voltage source vX with test current iX at the output node.
as far as my understanding says, gm= Id/Vgs and if the slope of characterstic curve is constant the gm can be approximated as rd. Please correct me if i am worng.
In the image attached by you the current source should be open because at the time of calculating output impedence we remove input voltage source. since Vgs=0, current source is open circuit. so if we remove the current source then the output impedece will be, Zo=(ro+Rs)||Rd.
Is this the way to do it?
Yes, you are absolutely right. But if you want to use this 1/gm resistance in your small-signal model. You need to change your model to this one:
Small-signal equivalent circuit of a FET with gate G, drain D and source S; a dependent current source gm vGS and resistor ro run from drain to source, with vGS = 1/gm across the source leg and Ig = 0A at the gate.
And now the voltage gain is equal to
Av = Rd/(1/gm + Rs)
Also notice that ro = rds = ΔVds/ΔId represent channel-length modulation similar to the Early effect in bipolar devices. And to represent channel-length modulation, i.e., variation of Id with Vds we add a resistor ro to small signal model.
Yes is is true that when we calculating output impedance we short a input voltage source.
So we connect the FET gate to ground. But we also replace the load resistance with a Vx test voltage source. So we can find Zo = Vx/Ix
So if you look at the circuit diagram
Small-signal equivalent circuit with a current source gm vGS in parallel with ro, a source resistor Rs to ground, drain resistor RD to ground, and test voltage vX with current iX at the output node.
You will see that Vgs is not equal 0V (only gate is connect to GND) not the source.
Vgs = -Is * Rs
Test voltage provide a current for Rs resistor so there will be a voltage drop across Rs resistor, so the gm*Vgs current source is not a open circuit. There will be additional current flow through Rs resistor. Is = Iro + (gm*Vgs).
But if we remove ro resistance from our small-signal model, then Vgs is indeed equal to Vgs = 0V, current source is open circuit. The output impedance will be, Zo = Rd.
  • Small-signal FET model with gate G on the left, drain D at top and source S at bottom. A current source gm·VGS runs from drain to source, with ro in parallel, and 1/gm shown in series with VGS across the gate-source path; Ig = 0A is labelled.
thanks a lot for telling me the difference in between gm and rd. I had a missconfussion regarding this concept. thanks for sharing this with me.
so Vo=Vds+Vs
where, Vds = (Io-gmVgs)*(ro||Rd): here Vgs=-Vs
Vds=(Io+gmVs)*(ro||Rd)
Vs=Rs*(Io) sum of current source and ro current will be the source current.
Vo=Vds+Vs
Vo=(Io+gmVs)*(ro||Rd)+(Rs*Io)
or
Vo=((Io+gm(Rs*Io))*(ro||Rd))+(Rs*Io)
Vo=Io*((1+gmRs))*(ro||Rd))+(Rs)
Vo/Io=((1+gmRs))*(ro||Rd))+(Rs)
right...?
but textbooks says the zo=Rd/(1+gmRs).
please clear this.
Try to find Zo if you remove Rd from the circuit.
Small-signal circuit of a common-source FET with source resistor Rs, showing current source gm·VGS and output resistance ro, with labels Id, Iro, iX and vX.
Vx - Iro•ro - Ix•Rs = 0 (1)
Ix = gm•Vgs + Iro (2)
Vgs = (-Ix)•Rs (3)
And now I substituting equation (2) and (3) to (1)
Vx - Iro•ro - (gm•(-Ix) •Rs + Iro)•Rs = 0
Now solve for Iro
Iro = (gm• Ix• Rs² + Vx) / (Rs + ro)
(4)
And substituting (4) to (1) and solve for Ix
Ix = Vx / (Rs + ro + gm•Rs•ro)
And finally
Vx/Ix = = Re + ro + gm•Re•ro = ro • (1+gm•RE + RE/ro)
Or we can write this equation
Ix•Rs + Iro•ro = Vx (1)
Iro = (Ix - Id) (2)
Id = (gm•(-Ix)•Rs) (3)
so after substitution
Ix•Rs + ( Ix - (gm•(-Ix)•Rs))*ro = Vx
next solve for I2
Ix = Vx / ( Rs + ro + gm*Rs*ro )
Vx/Ix = Rs + ro + gm*Rs*ro
so now if we add Rd resistor we have this 'exact' value
Rout = Rd||(ro+Rs+gm•ro•Rs) = Rd||( ro •(1+gm•Rs + Rs/ro) )
This expression, Rout = RD || (ro * (1 + gm * Rs)), is a good approximation provided that ro >> 1/gm.
Can you tell me the title of the book?
  • Small-signal circuit of a common-source FET stage with source resistor Rs, showing current source gm·VGS and output resistance ro, with labels Id, Iro, iX and vX and voltage VGS.
Hey thanks a lot. I get it where I was wrong. I thought that ro is directly connected to ground but it's connected to Rs. That's why I am taking Rd||ro.
Thanks a lot again.
