Feynman diagram with TikZ-Feynman
8 replies · 7K views
Homework Helper
TL;DR
How can I write a loop in ##\phi^4## theory with TikZ-Feynman?
Hi, I'm learning how to draw Feynman diagrams in LaTeX using the TikZ-Feynman package, but in https://arxiv.org/ftp/arxiv/papers/1601/1601.05437.pdf I don't see if it's possible to draw loops in ##\lambda \phi^4## theory, how can I draw a loop that goes from one vertex to itself?
Thanks
Well, it's ok but it's not what I was looking.
By now I can create a loop, for example with the code
Code:
\begin{tikzpicture}
  \tikzfeynmanset{
  every vertex = {dot}
  \begin{feynman}[small]
    \vertex (a1) {};
    \vertex[right=1.5cm of a1] (a2);
    \vertex[right=1.5cm of a2] (a3) {};
    \vertex[above=0.6cm of a2] (b);
    \diagram* {
      (a1) --[scalar] (a2) --[half left] (b) --[half left] (a2) --[scalar] (a3),
    \path (b)--++(90:0.3) coordinate (A);
    \draw (A) circle(0.3);
  \end{feynman}
\end{tikzpicture}
I draw
But I wonder if there is a better way to do it.
The node-to-node closed circuits don't have to be radially circular, but what's been presented here to you is not inconsistent with what apparently you asked for -- analogously, just as ##\TeX## requires you to be very specific in your commands, we need you to be very specific in saying what you're seeking, if we're to be optimally helpfully or assistively responsive.
Yes, I know they don't have to be, it's not this what matters, I did it circular because I like it.
Sorry for the ambiguous question, my question is, can I do the same I did but without doing this \path and \draw, only with the TikZ-Feynman commands?
Something like adding (b) --[loop] (b)
Thanks for your time.
I don't see why you're reluctant to use \path and \draw, and furthermore, if you're interested in more sophisticated than usual ##\LaTeX## graphics, I suggest that you might see how SVG can be brought in -- maybe have a look at https://wiki.inkscape.org/wiki/index.php/LaTeX
Hi!
I am aimed to learn how to draw Feynman Diagrams using ##\TeX## from scratch and I am looking for some advice :smile:
The document shared by @Gaussian97 really helps. I am trying to reproduce the first of the diagrams (section 2.2, A First Diagram).
I naively followed the following steps:
1) Adding the package \usepackage{tikz-feynman} and \tikzfeynmanset{compat=1.0.0} as a warning.
2) Then I simply copy-pasted the code for the first of the diagrams
Code:
\feynmandiagram[horizontal=a to b] {
    i1 -- [fermion] a -- [fermion] i2,
    a -- [photon] b,
    f1 -- [fermion] b -- [fermion] f2,
But the output was
Instead of the beautiful looking
What am I missing?
Any advice is very welcomed.
Thank you! :biggrin:
Hello @JD_PM, I'm not an expert at all in this kind of things but I had the same problem the first time I tried to use tikz-feynman, I don't know if this will work for you but I'll tell you how I fix it (if it doesn't work then I have no idea).
In my case, the problem is that I was using the PDFLaTeX compiler (which was the default option), but to use some functionalities of tikz-feynman you must use the LuaLaTeX compiler.
Here's how I discovered the problem and how I fixed it (in case it helps you)
In my case, I use TexMaker as the editor to write LaTeX documents. In it, you can look at the log and usually it gives a message when something is wrong (In any case, look if you have some document named "Name_of_the_document.log" and open it with the notepad), I got the following message:
Package tikz-feynman Warning: LuaTeX is required if you wish to have vertices automatically placed. You can disable this warning by setting /tikzfeynman/warn luatex=false on input line 50.
Then I found that, in fact, the first line of the log was
This is pdfTeX, Version 3.14159265-2.6-1.40.21 (MiKTeX 20.7) (preloaded format=pdflatex 2020.8.21)
And found that, when I click the Run button (that for me was some kind of magic that make appear a pdf with the things I wrote) it was really doing two things: PdfLaTeX + View PDF (which I assume are some kind of commands)
After looking into the options of the editor I finally found that there was the option of compiling using LuaLaTeX, and after doing that (and the View PDF) i finally got the diagram correctly and my log file start with
This is LuaHBTeX, Version 1.12.0 (MiKTeX 20.7) (format=lualatex 2020.8.22)
and there was no Package tikz-feynman Warning
Hope it helps you
