Final speed with mass, initial velocity, force, displacement
7 replies · 3K views · last reply
TDizzl
A 1000kg car is moving at 25ms when a net force of 200N acts to slow the car. This force acts while the car moves through a distance of 300m. Find the new speed.
Kinetic Energy equation
v2=u2+2as
Attempted the use of Kinetic Energy equation and v2=u2+2as
However the answer I get is 27.4 when the correct answer is 22.5
Unknown
Why don't you show us your calculations?
Unknown
Are the relevant equations unknown to you? How did you solve the problem then?
You result is correct with the data you gave. Check if they are the same given in the original text. And do not forget the unit next time. What is the unit of the speed? Is it really ms?
W=Fd
=200*300
=60000
60000=½*1000*v2-½*1000*252
=500v2-312500
372500 = 500v2
v2=745
v=27.3
Yea see for yourself, its a multiple choice question. And I changed the original post so it makes some sense.
  • Multiple-choice physics question 5: a 1000kg car moving at 25ms-1 has a 200N slowing force over 300m; options (A) 17.5ms-1, (B) 19.0ms-1, (C) 22.5ms-1, (D) 23.0ms-1.
v2=u2+2as
The force of 200 N is acting to slow the car, which is traveling initially at 25 m/s. If the force is acting to slow the car, it makes little sense to say that the car is going to speed up to 27.4 m/s. :oops:
Care to try again? I suggest you use F = ma here, in addition to v2=u2+2as
Thanks, I managed to get the answer, all I done was
27.5-25=2.5
25-2.5=22.5
TDizzl said:
W=Fd
=200*300
=60000
=500v2-312500
372500 = 500v2
v2=745
v=27.3
As the car slows down, the acceleration is negative. The force is opposite to velocity and displacement, so the work W is negative. You should have written W=Fd=-200*300= -60000 = 1/2mv2-1/2 m u2.
You changed the original post by changing the unit of speed from ms-1 to ms. Is it correct?
