Find an expression for the capacitor voltage
The discussion focuses on deriving an expression for the voltage ΔVC across a parallel-plate capacitor that affects the maximum height of a charged bead. Initially, the bead is shot upward with an initial speed v_0, reaching a maximum height y_max. After charging the capacitor with the bottom plate negative, the goal is to find the voltage that reduces the bead's maximum height to half, or 1/2y_max. The relevant equations include V = EΔs, E = f/q, and kinematic equations, which are used to relate the forces acting on the bead to the voltage across the capacitor.
  • Understanding of kinematics, particularly the equations of motion.
  • Familiarity with electric fields and forces, specifically E = f/q.
  • Knowledge of capacitor behavior and voltage relationships.
  • Basic principles of mechanics, including mass, acceleration, and gravitational force.
  • Study the derivation of electric field strength in capacitors, focusing on parallel-plate configurations.
  • Learn about the relationship between force, mass, and acceleration in physics.
  • Explore kinematic equations in-depth, particularly how they apply to vertical motion under gravity.
  • Investigate the effects of electric fields on charged particles in motion.
This discussion is beneficial for physics students, educators, and anyone interested in understanding the interplay between electric fields and motion in charged particles, particularly in capacitor systems.
neilson18
[/B]
An uncharged parallel-plate capacitor with spacing d is horizontal. A small bead with mass m and positive charge q is shot straight up from the bottom plate with speed v_0. It reaches maximum height y_max before falling back. Then the capacitor is charged with the bottom plate negative.
Find an expression for the capacitor voltage ΔVC for which the bead's maximum height is reduced to 1/2y_max. Ignore air resistance.
Express your answer in terms of the variables m, d, q, and appropriate constants.
V = EΔs
E=f/q
f=ma
v_f^2 = v_o^2 + 2aΔx
I'm not sure how to approach this problem. I thought you could use a kinematics equation to solve for acceleration and then use that to find force, then E field, then V, but I was getting an answer that depended on v_o which is not allowed.
We have:
v_i = v_o
v_f = 0
a = ?
t = ?
Δx = y_max = d
0 = v_o^2 + 2ad/2
=> a = -v_o^2/d
=> f = -mv_o^2/d
=> E = -mqv_o^2/d
=> V = -mqv_o^2
So now I'm not sure where to go from here.
For the first shot the only force acting on the bead is gravity, producing an acceleration of g downwards. What is the expression for ##y_{max}## under those conditions?
How would you have to modify the acceleration in order to reduce that height by half?
  • · Replies 18 ·
