Find ##b-a## which satisfies following limit
12 replies · 2K views
MatinSAR
Find ##b-a## which satisfies following limit:
## \lim_{x \rightarrow 1} {\frac {x-2} {x^3+ax+b}} = -\infty##
Please see below.
The limit is equal to ##\frac {-1} {1+a+b}## .
so I can say that ## a+b = -1 ##.
But I cannot find another equation to find both ##b-a##.
You need to make the denominator zero at [itex]x = 1[/itex], but you don't want it to change sign, or the limit from below will be -1 times the limit from above, and the two-sided limit will not exist. Thus [itex](x - 1)^2[/itex] must be a factor of the denominator.
Reply
Yes. I understand now. Thanks for your help.
Setting [tex] \left. \frac{d}{dx}(x^3 + ax + b)\right|_{x=1} = 0[/tex] will give [itex]a[/itex] directly, but fully factorising the denominator as above will confirm that the other linear factor is positive near [itex]x = 1[/itex].
Reply
MatinSAR said:
Homework Statement: Find ##b-a## which satisfies following limit:
Relevant Equations: Please see below.
This hypothesis of the question seems to fully specify ##a## and ##b##?
Reply
I'm not sure if I understand your question well.
The question asks for ##b-a## value. So we need to find both ##a## and ##b##. I found ##b-a = 5 ##.
PeroK said:
This hypothesis of the question seems to fully specify a and b?
MatinSAR said:
The question asks for b−a value. So we need to find both a and b. I found b−a=5.
I don't believe it asks you to find both a and b, just the value of b - a.
If I understand @PeroK's comment/question correctly, he seems to be questioning whether both a and b need to be found.
In any case, how did you come up with b - a = 5?
Reply
Quite the reverse. Why ask for ##b - a## when we can find both ##a## and ##b##? It suggested to me that any ##a, b## with a common difference would work.
Reply
PeroK said:
Quite the reverse. Why ask for b−a when we can find both a and b? It suggested to me that any a,b with a common difference would work.
That's probably the correct interpretation, although "find b - a which satisfies following limit" doesn't seem to be clearly stated. A better problem statement in this case would be "find a and b that satisfy the following limit."
Reply
Yes, that is misleading, but i have seen many problems like that. They make you think that there is a clever way to find what is asked without the calculation for both numbers, just to be disappointed when you see the author's solution.
Reply
@Mark44 @PeroK @martinbn What I have done to solve using @pasmith help :
haruspex said:
Yes, that works, but maybe this is a bit easier:
##(x-1)^2## being a factor of ##P(x)## implies ##x-1## is a factor of ##P'(x)##. So solve ##3x^2+a=0## for ##x=1##.
I didn't know about this ...
It's far easier than what I have done!!! Thanks a lot for your help.
