Find Dielectric Constant Given Charges
The discussion revolves around determining the dielectric constant of a dielectric slab inserted into an air-filled parallel-plate capacitor after it has been charged. The problem involves understanding the relationship between charge, capacitance, and the dielectric constant.
  • Participants explore the equations related to capacitance and the dielectric constant, questioning how the dielectric affects charge accumulation. Some express uncertainty about the necessary parameters such as area and distance between the plates.
Participants are actively engaging with the problem, raising questions about the relevant equations and the implications of inserting a dielectric. There is a recognition that while certain equations are applicable, specific values needed for calculations are missing.
Participants note the absence of information regarding the area and distance of the capacitor plates, which complicates the ability to directly calculate the dielectric constant.
Runaway
When a certain air-filled parallel-plate capacitor is connected cross a battery, it acquires a charge (on each plate) of 130 μC. While the battery connection is maintained, a dielectric slab is inserted into and fills the region between the plates. This results in the accumulation of an additional charge of 190 μC on each plate.
What is the dielectric constant of the dielectric slab?
k = E0/E
I have no idea, any guidance as to where to start would be great.
What's the equation for the capacitance of a parallel-plate capacitor? How does this depend on the dielectric constant?
C= k[tex]\epsilon[/tex]0 A / d
so k= C/ ([tex]\epsilon[/tex]0 A / d)
But I still don't have A or d, so how does that help me?
It should be [tex]\epsilon[/tex], not [tex]\epsilon[/tex]0, if a dielectric is present. The dielectric constant is just k=[tex]\epsilon[/tex]/[tex]\epsilon[/tex]0.
Well, you know that Q=CV for both situations: with the dielectric and without. You also know that V is a constant.
ok, so k = q/q0
  • · Replies 17 ·
  • · Replies 20 ·
