Find eigenfunctions and eigenvalues of an operator
The discussion focuses on finding the eigenfunctions and eigenvalues of the operator \(\hat T = \frac{{\hat L_z^2}}{{2I}}\). The relevant differential equation derived is \(-\frac{{\hbar^2}}{{2I}}\frac{{\partial^2}}{{\partial \varphi^2}}f = \lambda f\), leading to the characteristic equation \(\lambda + \frac{{\hbar^2}}{{2I}}\frac{{\partial^2}}{{\partial \varphi^2}} = 0\). Participants clarify that the correct form of the equation should be rearranged to \(\frac{\partial^2}{\partial \varphi^2} f = -k^2 f\), where \(k^2 = \frac{2I\lambda}{\hbar^2}\). This equation is recognized as a standard form, suggesting familiarity with solving such differential equations. The conversation emphasizes the importance of correctly identifying and manipulating the differential equation to find solutions.
fdbjruitoirew
\hat T = \frac{{\hat L_z^2}}{{2I}} = - \frac{{{\hbar ^2}}}{{2I}}\frac{{{\partial ^2}}}{{\partial {\varphi ^2}}}
Find eigenfunctions and eigenvalues of this operator
It leads to the differential eqn
- \frac{{{\hbar ^2}}}{{2I}}\frac{{{\partial ^2}}}{{\partial {\varphi ^2}}}f = \lambda f
it has the characteristic eqn
\lambda + \frac{{{\hbar ^2}}}{{2I}}\frac{{{\partial ^2}}}{{\partial {\varphi ^2}}} = 0
then I don't know how to do the next step
If I said its a wave equation would that help?
then just follow the steps for solving Schrodinger eqn that was written in textbook, is it your idea?
No just solve it as a regular maths equation. What sort of function when differentiated twice gives you the same function multiplied by a negative constant?
That's not the characteristic equation for the differential equation. For one thing, derivatives shouldn't appear in it.
If you rearrange the original differential equation slightly, you get
$$\frac{\partial ^2}{\partial \varphi^2} f = -k^2 f$$ where ##k^2 = \frac{2I\lambda}{\hbar^2}## is a constant. Surely, you've seen that kind of differential equation before.
