Find equilibrium points given 2 differential equation
The equilibrium points for the system of differential equations defined by \(\dot{x} = -pxy + qx\) and \(\dot{y} = rxy - sy\) are determined to be (0,0) and \((s/r, q/p)\). The analysis reveals that when \(y = 0\), \(x\) must also be 0, confirming (0,0) as an equilibrium point. For non-zero \(y\), solving the equations leads to the second equilibrium point \((s/r, q/p)\), where \(p\), \(q\), \(r\), and \(s\) are positive constants with \(p \neq r\).
  • Understanding of differential equations and equilibrium points
  • Familiarity with algebraic manipulation of equations
  • Knowledge of the significance of constants in mathematical modeling
  • Basic calculus concepts related to stability analysis
  • Study the stability of equilibrium points in nonlinear differential equations
  • Learn about phase plane analysis for systems of differential equations
  • Explore the use of Jacobian matrices in determining stability
  • Investigate the role of parameters in dynamic systems and their impact on equilibrium
Students and professionals in mathematics, engineering, and physics who are studying differential equations and seeking to understand equilibrium points and their implications in dynamic systems.
fireychariot
\dot{x} = -pxy + qx, \dot{y} = rxy - sy
where p,q,r and s are positive constants (p does not equal r)
Question is : Determine all the equilibrium points for the system of differential equations given above, expressing your answers in terms of p,q,r and s
I do know one point is (0,0) however am stuck in finding out the others. I factorise them to get
x(-py + q) = 0
y(xr - s) = 0
Any hints will be much appreciated
x(-py + q) = 0
y(xr - s) = 0
Okay, and then what? If you are taking a differential equations course, we should be able to assume that you can do basic algebra. You should know "if ab= 0 then either a= 0 or b= 0."
-py+q=0 so do I say y = p/q how do I find the x coordinate from that? Is that when x =0 or do I substitute it into my second equation?
I mean y = q/p sorry. What's confusing is the fact that it is variables as the constants instead of numbers so any more hints would be grateful.
?? Constants are numbers.
Your two equations are
x(-py + q) = 0
y(xr - s) = 0
clearly, (0, 0) is a root. In fact if y= 0, -py+q is not 0 (unless q happens to be 0 which I am assuming is not true) so we must have x= 0 also.
If y is NOT 0 then we must have xr- s= 0 so that x= s/r. Putting that into the first equation gives s/r(-py+ q)= 0 so that y= q/p. (s/r, q/p) is also an equilibrium point.
If x is not 0 we can do the same thing but get the same point again.
  • · Replies 27 ·
