Find Forces Given Air Pressure and Velocity
  • Topic:
  • Thread starter mathmari
    Forces
mathmari
MHB
Hey! :o
Air of pressure $p_0$ and velocity $|\overrightarrow{u}_{A}|=|\overrightarrow{u}_{B}|=c$ enters the space $D$ from the sections $A, B$ of surface $S$. If at the orifices the distribution of the pressure and the velocity is uniform and at the exit $\Gamma$ the pressure is equal to the atmospheric one $P_a$, find the forces $R_x, R_y$ acting on the support $\Delta$ (air density $\rho_a$).
The solution that I found in my notes is the following:
$$\overrightarrow{F}_{W_0}=-\int_{\partial{W_1}}p\overrightarrow{n}dA-\int_{\partial{W_1}}\rho \overrightarrow{u}(\overrightarrow{u} \cdot \overrightarrow{n})dA$$
$\overrightarrow{F}_{W_0}$ is the force over the solid boundary $\partial_{W_0}$ (square ΑΒΓΔ)
Continuity equation: $$u_{\Gamma}S_{\Gamma}=u_AS_A+u_BS_B \Rightarrow u_{\Gamma}2S=cS+cS \Rightarrow u_{\Gamma}=u_A=u_B=c$$
$$\text{ Section } A : \overrightarrow{n}_A=\hat{i} \ \ , \ \ \overrightarrow{u}_{A}=-c\hat{i} \\ \text{ Section } B : \overrightarrow{n}_B=\frac{\sqrt{2}}{2}(\hat{i}-\hat{j}) \ \ , \ \ \overrightarrow{u}_{B}=c\left (-\frac{\sqrt{2}}{2}(\hat{i}-\hat{j})\right ) \\ \text{ Section } \Gamma : \overrightarrow{n}_{\Gamma}=-\hat{j} \ \ , \ \ \overrightarrow{u}_{\Gamma}=-c\hat{j}$$
$$\overrightarrow{u}_{A} \cdot \overrightarrow{n}_{A}=-c \\ \overrightarrow{u}_{B} \cdot \overrightarrow{n}_{B}=-c \\ \overrightarrow{u}_{\Gamma} \cdot \overrightarrow{n}_{\Gamma}=c$$
$$\int_{\partial{W_1}}p\overrightarrow{n}dA=P_AS\hat{i}+P_BS\frac{\sqrt{2}}{2}(\hat{i}-\hat{j})+P_{\Gamma}2S(-\hat{j})=P_0S\left (\hat{i}+\frac{\sqrt{2}}{2}(\hat{i}-\hat{j})\right )-2P_aS\hat{j}=P_0S\left (1+\frac{\sqrt{2}}{2}\right )\hat{i}-\left (P_0S\frac{\sqrt{2}}{2}+2P_aS\right )\hat{j}$$
$$\int_{\partial{W_1}}\rho \overrightarrow{u}(\overrightarrow{u} \cdot \overrightarrow{n})dA=\rho_a [\overrightarrow{u}_A (\overrightarrow{u}_A \cdot \overrightarrow{n})S_A+\overrightarrow{u}_B (\overrightarrow{u}_B \cdot \overrightarrow{n})S_B+\overrightarrow{u}_{\Gamma} (\overrightarrow{u}_{\Gamma} \cdot \overrightarrow{n})S_{\Gamma}]=\rho_a [-c\hat{i}(-c)S-c\frac{\sqrt{2}}{2}(\hat{i}-\hat{j})(-c)S-c\hat{j}c2S]=\rho_a c^2S\left (\hat{i}+\frac{\sqrt{2}}{2}(\hat{i}-\hat{j})-2\hat{j}\right )=\rho_ac^2S\left (\left (1+\frac{\sqrt{2}}{2}\right )\hat{i}-\left ( \frac{\sqrt{2}}{2}+2\right )\hat{j}\right )$$
$$\overrightarrow{F}_{W_0}=-P_0S\left (1+\frac{\sqrt{2}}{2}\right )\hat{i}+\left (P_0S\frac{\sqrt{2}}{2}+2P_aS\right )\hat{j}-\rho_a c^2S\left (1+\frac{\sqrt{2}}{2}\right )\hat{i}+\rho_a c^2S\left (\frac{\sqrt{2}}{2}+2\right )\hat{j}$$
$$F_{W_0,x}=-\left (P_0+\rho_a c^2\right )S\left (1+\frac{\sqrt{2}}{2}\right )<0 \\ F_{W_0, y}=\left (\left ( P_2\frac{\sqrt{2}}{2}+2P_a\right ) +\rho_ac^2\left (\frac{\sqrt{2}}{2}+2\right )\right )S>0$$
Balance of the construction:
$$R_x+F_{W_0, x}=0 \Rightarrow R_x=-F_{W_0, x}>0 \\ -R_y+F_{W_0, y}=0 \Rightarrow R_y=F_{W_0, y}>0$$
How we have we found that $\overrightarrow{n}_B=\frac{\sqrt{2}}{2}(\hat{i}-\hat{j})$ ?? (Wondering)
Could also explain to me how we have calculated the integrals $\int_{\partial{W_1}}p\overrightarrow{n}dA$ and $\int_{\partial{W_1}}\rho \overrightarrow{u}(\overrightarrow{u}\cdot \overrightarrow{n})dA$ ?? (Wondering)
  • Hand-drawn diagram of a square duct ABΓΔ with a red control volume boundary labelled ∂W1 and ∂W0, inlets A and B with velocities uA and uB, outlet Γ with velocity uΓ, a dashed diagonal D, a 45° angle, and support forces Rx and Ry at corner Δ.
Why does it stand that $R_x+F_{W_0, x}=0$ and $-R_y+F_{W_0, y}=0$ ?? (Wondering)
Hey! (Wave)
The wall is fixed and the system presses itself into the top left corner.
That means that $R_x$ and $R_y$ will be exactly as large as needed to counter the forces generated by the fluid.
Put otherwise, the system as a whole is in static equilibrium (what they termed "Balance of the system").
That means:
$$\sum F_x = 0\\
\sum F_y = 0 \\
\sum M = 0$$
(Thinking)
I like Serena said:
Hey! (Wave)
That means:
$$\sum F_x = 0\\
\sum F_y = 0 \\
\sum M = 0$$
(Thinking)
What is $M$ ?? (Wondering)
Could you explain to me the signs at the equation $-R_y+F_{W_0, y}=0$ ?? (Wondering) Why is at $R_y$ a minus and at $F_{W_0, y}$ a plus?? (Wondering)
$M$ is the symbol for moments or torques, which make the system rotate. (Nerd)
It's not included in your problem though.
More specifically, static equilibrium is often written as something like:
\begin{aligned}
\overset{+}{\rightarrow} &\sum_i F_{i,x} &=0 \\
+\!\!\uparrow &\sum_i F_{i,y} &=0 \\
\underset+\curvearrowleft &\sum_i M_{i,\text{arbitrary point}}&= 0
\end{aligned}
The arrows indicate which direction we count as plus.
Since the direction of $R_y$ (as it is drawn) is in the opposite direction of the arrow for vertical forces, we give it a minus sign.
Apparently $F_{W_0, y}$ is going in the direction of the arrow (up), although I don't see it in the drawing. (Wasntme)
Which force is $F_{W_0, y}$ ?? (Wondering)
From the problem statement:
[box=yellow]$\overrightarrow{F}_{W_0}$ is the force over the solid boundary $\partial_{W_0}$ (square ΑΒΓΔ) [/box]
That is, the force $F_{W_0, y}$ is the vertical component of the force that applies to the box due to fluid movements caused by differences in pressure.
