Find mass per unit length of a string graphically
5 replies · 5K views
jbumbes
frequency, Tension, mass, mode of vibration
v = sqrt(T/μ)
length of string is 2.14m
weight .00247kg
mass per unit length (μ) .00089
However, I need to confirm this graphically. I solved for mass per unit length
μ = T/V^2
or sqrt(μ) = sqrt(T)/v
however, I have already graphed this and the slope is 33.5. With velocity on the y-axis and sqrt(T) on the x which seems way too off. Basically I have to find the experimental μ graphically.
That gives an error of about 23% then - the difference between the experimental and real value for linear density?
You did take the wavelength to be the twice the distance between two adjacent nodes?
Is the string running straight from the top of the pulley to the other end where it is fixed or tied to the vibrator?
weight .00247kg
This in itself is strange. Can you explain how you calculated this ?
That is the experimentally determined value, which then gives a 23% difference between the two.
I mean that 2.47/2.14 is not 0.89 but 1.15 gram/meter
