Find maximum of the function N(t) without Calculus
The discussion revolves around finding the maximum value of the function N(t) without using calculus. The function is presented as N(t) = 1456 * 0.996^(t^2 - 48t), and participants explore methods to determine the maximum value through algebraic techniques and reasoning.
  • Participants discuss the possibility of using algebraic methods, such as completing the square, to find the maximum. There are questions about the significance of symmetry in the function and the role of the axis of symmetry in determining maximum or minimum points. Some participants also raise concerns about the correctness of the function's formulation.
The discussion is active, with various participants offering insights and questioning assumptions. Some participants suggest algebraic steps that could clarify the maximum value, while others emphasize the importance of understanding the function's structure. There is no explicit consensus on the best approach yet.
Some participants note potential issues with the original function's formulation, specifically regarding the presence of a minus sign that could affect whether the function has a maximum or minimum. There is also mention of the need for clarity in the algebraic manipulation involved in finding the maximum.
Mathman2013
Find maximum of N(t) without Calculus
N(t) = 1456*0.996^(t^2 - 48*t)
How would you go about finding maximum value for this function without Calculus? You can draw in it a CAS tool like Geogebra, NSpire or Maple. And use the maximise ability. But is possible to do it by hand? Pre-Calculus?
PF guidelines ask you to post an attempt at solution before we can help.
When is something like this at a maximum ?
I have tried to say I take the internal function y=t^2-48*t and solve y =0, then t^2-48*t = 0, then I get t = 0 or t = 48, and it looks to be the function is symetrical, so if I divide by 48 by 2, I get t = 24, and N(24) = 14648.13868 which looks to be a maximum. But is there a better way?
caz said:
This is similar to maximizing 0.996^x. What does this say about x?
if x increases then N decreases?
caz said:
If you want to maximize N, what do you want x to do?
x to increase to. But why do I get the maximum point if solve the internal function as eqn: t^2-48*t=0 and divide one of the roots by two? Is it only do to symetry?
I love the conditioned reaction to solve y = 0 and the ten digit accuracy of N(24), but unfortunately both are irrelevant here. The direct questions by @caz are more to the point.
If you want to maximize ##a^x## for a number ##a## between 0 and 1, what do you want for ##x## ? that it is zero, at a minimum, or at a maximum ?PS: @caz : in PF, we don't give the answer on a silver plate, but try to let the poster find his/her way towards the solution by him/herself using gentle nudges and inviting questions ...
The form ##y=ax^2+bx+c ## is a parabola whose axis of symmetry can be found by completing the square. That's the algebraic way of coming up with the number ## t=24 ## that you did.
Yes, if ##y=f(x)##, if it’s quadratic (something like ##f(x)=A x^2 + Bx + C## where ##A, B, C## are constants), then the point halfway between two zeros of ##f## will be either a maximum or a minimum.
Maybe worth noting that in the quadratic formula, the axis of symmetry (which gives the x co-ordinate of the min/max) is given by the part of the formula not under the square root sign.
I think the OP left off a minus sign for ## N(t) ##. Otherwise the function that he has will have a minimum and not a maximum. (His graph in post 3 is also incorrect otherwise).
No, the function is presented $$N(t)=1456 \cdot 0.996^{t^2-48 \cdot t}$$, where $$t \geq 0$$
My mistake. I didn't see the ^ in the OP. In any case ## t^2-48t=(t-24)^2-576 ##.
To do the arithmetic of ## .996^{-576} ## is the next problem. One possibility would be to use logarithms.
For this equation, you indeed don't need calculus to know t that will maximize N(t). If you add a simple algebraic step, the answer will be shown more clearly.
You divide by 2 because this is the way to complete the square and this way find the vertex of the parabola which is a max or a min.
How about the binomial expansion?
  • · Replies 29 ·
  • · Replies 17 ·
12K
