Find out How Long 9.5 W Battery Can Run Camera
  • Thread starter Thread starter Travian
    Battery Camera
The discussion centers on calculating the operational time of a camera powered by a BP-927 battery in a 9.5W recording mode. The battery specifications indicate a voltage of 7.2V and a capacity of 2000 mAh. Using the formula I = P / V, the current drawn is determined to be 1.319A. The total time the camera can operate is calculated to be approximately 90.98 minutes, derived from the relationship between current and battery capacity.
  • Understanding of electrical formulas, specifically Ohm's Law (I = P / V).
  • Knowledge of battery specifications, including voltage (V) and capacity (Ah).
  • Familiarity with unit conversions, particularly between amp-hours and seconds.
  • Basic concepts of energy calculations (E = V x Ah).
  • Research battery capacity calculations and their implications on device usage time.
  • Learn about different battery types and their specifications, focusing on lithium-ion technology.
  • Explore advanced energy consumption calculations for electronic devices.
  • Investigate the impact of varying power consumption on battery life in practical applications.
Electronics enthusiasts, camera operators, and anyone involved in battery management and energy consumption analysis will benefit from this discussion.
Travian
How long the camera can be
operated in the 9.5 Watts recording mode using an initially fully charged
battery.
P = 9.5 W,
V = 7.2 V,
I = 1.3194 A
(Cb) = I x t
(Cb) = I x t = 1.3194 x 3600 = 4749,84 minutes (79+ hours)?
What are the characteristics (specifications) for the battery?
“BP-927” DC rechargeable lithium battery pack.
Damn i thought it doesn't matter.
Sure it matters! There are many different battery types available with different energy storage capabilities. There are a number of "replacement" batteries for the original BP-927 that have various ratings, but a quick web search seems to indicate that the original battery pack had specs of 7.2V and 2000 mAh. So 2000 mAh is the amount of charge that the battery can deliver before it is exhausted and requires recharging.
The device power consumption of 9.5W at 7.2V can be converted to a value for the operating current. Current x time is the amp-hours.
Im having some trouble. What should I do next? Calculate current x time?
More or less, yes; It's the time that you need to solve for. First calculate the current drawn from the battery pack when it's providing 9.5W to the load. Then current x time is the amp-hours. Solve for time.
Current:
I = P / V
I = 9.5W / 7.2V = 1.319A
Current x time:
Cb = I x t
Cb = 1.319A x 3600s = 4748.4s = 79.14minutes
If this is correct then what does 200mAh have to do with this?
Time is what you want to solve for. Why are you plugging it a value?
The battery holds 2000 mAh of charge. At 9.5W it's delivering current at 1.319A. How many seconds at 1.319A will make 2000 mAh of charge?
mm so it's 2000/1,319 = 1516s = 25 min?
You've got the right idea, but you need to keep track of all the units:
(2000 mA*hr)/(1319 mA) = ?
2000 mA x 3600 / 1319 mA = 5458,68s = 90,978 min.
Thank you for your help!
There is more to this exercise, should i post it here, or create a new thread?
It's your choice.
Calculate the total energy stored in the BP-927 battery when it is fully charged.
P = 9.5 W,
V = 7.2 V,
I = 1.3194 A
E = V x Ah
E = 7.2V x 2Ah = 14.4 Joules..?
14 J ?
With this energy you can use your camera for some seconds.
Once again, be careful of the units. 2Ah is 2 amps x 1hr. An hour is 3600 seconds.
Oh right.
E = 7.2V x 2A x 3600s = 7.2V x 7200Ah = 51840 J
However what bothers me is...
It was 2 Ah before. After i multiply 2 Ah by 3600s, is it again Ah?
Travian said:
Oh right.
Sorry, I don't understand the question. Can you point to a particular calculation where this was the case?
I figured it out.
Thank you for your help.
I'll keep in mind that Ah = A x 3600s :]
  • · Replies 18 ·
111K
