Find perpendicular vectors and angles
5 replies · 5K views · last reply
thomas49th
I'm awful with vectors. I know the dot product rule and the uses to find perpendicular vectors and angles. I know about multiplying vectors (a1b1 + a2b2 + a3b3). I know vector arithmetic.
But i can't do:
r = 8i + 12j + 14k + t(i + j - k)
where t is a parameter
The point A has co-ordinates (4,8,a), where a is a constant. The point B has co-ordinates (b,13,13), where b is a constant. Points A and B lie on the line l1.
a) Find the values a and b
Well i presume i need to find the parameter t first... how? I don't have enough information do i?
thomas49th said:
But i can't do:
Can't do what?
What line? And what does this have to do with r above?
sorry the question is
The line l1 has vector equation:
My bad. (I realized what you meant shortly after I posted.)
Think of it this way: All points on that line must satisfy the parametric equations:
x = 8 + t
y = 12 + t
z = 14 - t
(where t is just a parameter that takes on all real values.)
Since points A and B are on that line, they must satisfy those three equations. See what you can deduce from that. Hint: Start by finding the value of the parameter t for each point. (You have all the information needed.)
4 = 8 + t
8 = 12 + t
a = 14 + t
b = 8 + t
13 = 12 + t
13 = 14 + tpoint a t = -4
point b t = 9
a = 18, b = 9
Okay cheeers :)
Next question:
Given that point O is the origin, and that the point P lies on l1 such that OP is perpendicular to l1
b) Find the coordinates of P
i've sketched a graph of it. using the dot product rule, a.b =0 (0 as it's cos(90))
so does that mean vector a x vector b = 0?
Where exactly now?
Sorry for the delay--I forgot that you had a second question.
thomas49th said:
Next question:
No. The cross product will not be zero, only the dot product.
Call the point P (x, y, z). Thus the vector OP is (x, y, z). That point must satisfy two conditions:
(1) The vector OP must be perpendicular to the line, thus its dot product with a vector parallel to the line must be zero. (Find a vector parallel to the line--any one will do.)
(2) The point P must be on line, thus satisfy the same parametric equations from before. (Solve for t.)
