Find potential between 2 conc. cyl. with grounded strip
The discussion focuses on solving the potential function \(\Phi(r,\phi)\) for two concentric cylinders with radii \(a\) and \(b\) (where \(b>a\)) and a grounded strip along the z-direction. The boundary conditions include \(\Phi(r, 2n\pi) = 0\), \(\Phi(a,\phi) = \phi_1\), and \(\Phi(b,\phi) = \phi_2\). The proposed solution involves using the Laplace equation in polar coordinates and results in a series expansion that incorporates sine and cosine functions. However, the user expresses concerns about the legitimacy of the solution due to potential discontinuities and the need for symmetry in the boundary conditions.
  • Understanding of Laplace's equation in polar coordinates
  • Familiarity with Fourier series and boundary value problems
  • Knowledge of potential theory in electrostatics
  • Ability to manipulate series expansions and convergence criteria
  • Study the derivation of solutions to Laplace's equation in cylindrical coordinates
  • Learn about boundary value problems and their applications in electrostatics
  • Explore Fourier series and their role in solving periodic boundary conditions
  • Investigate the implications of symmetry in potential functions and boundary conditions
This discussion is beneficial for physics students, electrical engineers, and mathematicians interested in electrostatics, boundary value problems, and potential theory. It provides insights into solving complex problems involving cylindrical geometries and grounded conductors.
vemarli
Two concentric cylinders with radii a & b (b>a) with an infinitely long grounded strip along the z-direction are given potentials \phi_1 and \phi_2.
Find \Phi(r,\phi) for a<r<b
Boundary conditions:
\Phi(r,2n\pi)=0
\Phi(a,\phi)=\phi_1
\Phi(b,\phi)=\phi_2<br />
The laplace equation in polar coordinates (as the solution is independent of z)
<br /> \Delta^2\Phi=0
Ansatz:
\Phi=R(r)Q(\phi),
compute
\frac{r^2}{R(r)Q(\phi)}\Delta^2(R(r)Q(\phi))=0
\frac{1}{r}\frac{d}{dr}(r\frac{dR}{dr})+\frac{1}{Q(\phi)}\frac{dQ(\phi}{d\phi^2}=0
Assume that the first term equals n^2, which means that the second one equals -n^2
-> Solutions: (n=0):
R(r)=a_0 +b_0ln(r);
Q(\phi)=A_0+B_0\phi
and (n>1):
R(r)=a_nr^n +b_nr^{-n};
Q(\phi)=A_ncos(n\phi)+B_nsin(n\phi)
\Phi(r,\phi)=(a_0 +b_0ln(r))(A_0+B_0\phi)+\sum_{n=1}^\infty(a_nr^n +b_nr^{-n})(A_ncos(n\phi)+B_nsin(n\phi))
[/B]
From the boundary conditions we see that the solution needs to be periodic in \phi=2n\pi; n=0,1,... which leads to
A_n=A_0=B_0=0
This gives the solution:
\Phi(r,\phi)=\sum_{n=1}^\infty(a_nr^n +b_nr^{-n})sin(n\phi)
Where I have now put B_n coefficients into a_n and b_n.
Now I need to satisfy
\Phi(a,\phi)=\phi_1
\Phi(b,\phi)=\phi_2
\Phi(a,\phi)=\sum_{n=1}^\infty(a_na^n +b_na^{-n})sin(n\phi)=\phi_1
\Phi(a,\phi)=\sum_{n=1}^\infty(a_nb^n +b_nb^{-n})sin(n\phi)=\phi_2
The problem with this is that I would say that the solutions need to be symmetric for phi = [0,pi] and phi = [0,-pi] i.e. The solution should be mirrored in these two domains Phi(r,phi)=Phi(r,-phi), and thus it would be sufficient to solve the boundary conditions only in one of these domains. But only having sinus functions would lead to a discontinuity at phi=plusminus pi... which makes me question the legitimity of this solution.
Furthermore I don't know how to satisfy the boundary conditions on r=a,b; I guess that if I assume phi_1>phi_2 then a_n=0, likewise, phi_1<phi_2 gives b_n=0 and phi_1=phi_2 gives R(r) = constant.
But, to satisfy the finite constant potentials at r=a,b means that we can not have sin(n\phi) solutions i.e. n=0 Which also means that we can't satisfy the fact that the strip is grounded (Phi=0).
So all in all I would assume that the ansatz is wrong... can anyone give a helping hand??
Obviously, if I may comment, the strip is situated at a<r<b and thus not in contact with the two cylinders (which would otherwise mean that they would all be equipotential and grounded). I wonder if the solution is a combination of two cases, r=a,b and a<r<b? What if I made the strip such that it was between a+d<r<b-d and then let d->0 (but never reach d=0?). Or is the ansatz simply wrong?
Consider whether or not the boundary conditions can be satisfied with ##n## not being an integer.
