Find solutions to non-linear equation
  • Thread starter Thread starter mackhina
    Non-linear
3 replies · 3K views
mackhina
Question:
(t-1)^4+5=3
I know the answer to the question states that there are no solution, but I would like to understand the intuition behind this. If I had this in a test I would waste ages trying to work out why I couldn't solve it.
Any advice would be heaps appreciated.
Thanks
Mick
mackhina said:
Question:
(t-1)^4+5=3
This equation is equivalent to (same solution set) (t - 1)4 = -2. There are no real numbers that can be raised to the fourth power to result in a negative number, so the solution set is empty.
The same would be true if (t - 1) were raised to any even power.
Start solving, you should find out what the reason is quite fast.
Please use the template next time.
Note: there is no solution in R (real numbers), it doesn't mean there is no solution at all.
Edit: beaten by Mark.
Thanks for your help Mark, that made it totally obvious. Much appreciated.
