Find the critical points of (x^2+y^2-4)(x+y) and their nature
The problem involves finding the critical points of the function f(x,y) = (x^2+y^2-4)(x+y) and determining their nature. The context is within the subject area of multivariable calculus or analysis, focusing on critical points and their classification.
  • Participants discuss the partial derivatives of the function and their implications for finding critical points. There are attempts to manipulate the equations, including subtracting one from the other and factoring. Some participants express confusion about the solutions and the nature of the intersection points.
There is an ongoing exploration of the critical points, with some participants providing guidance on approaches to take. Multiple interpretations of the solutions are being discussed, and there is recognition of the need for clarity regarding the correct pairs of solutions.
Participants note discrepancies in the solutions, with some values being questioned. There is mention of a solutions manual that provides values without methods, leading to confusion. The original poster and others express a desire to understand the analytical process rather than relying on computational tools.
rbnvrw
Hi,
I am studying for my Analysis final and came across this problem I just can't get my head around:
Find the critical points of f(x,y) = (x^2+y^2-4)(x+y) and their nature.
\vec{\nabla} f(x,y) = \vec{0}
\frac{\partial f(x,y)}{\partial x} = 3x^2+2xy+y^2-4 = 0
\frac{\partial f(x,y)}{\partial y} = 3y^2+2xy+x^2-4 = 0
These are both ellipses with center (0,0) and angles \frac{5\pi}{8} and \frac{\pi}{8} respectively.
According to Wolfram Alpha, there are four intersection points. (Click here to view) However, I need to solve this problem analytically and I wish to understand how it is done.
I have tried to eliminate a variable from the equations, but it is not possible due to the 2xy term. Another solution would be to write the ellipses in a parametric form, but this I feel would be overly complicated.
Could anyone please shed some light on this?
Thanks in advance!
rbnvrw said:
Hi,
The first thing I would do is subtract one equation from the other to get
3(x^2- y^2)+ (y^2- x^2)= 2(x^2- y^2)= 0
so that either y= x or y= -x.
Thanks in advance!
Subtract the second equation from the first one and factorise.
ehild
Thanks for your advice.
However, this doesn't give me the four points of intersection. If I take the solutions y=\pm x, I get the solutions (0,0) \wedge (\pm \sqrt{2},\pm \sqrt{2}).
However, the points (\pm \sqrt{\frac{2}{3}},\pm \sqrt{\frac{2}{3}}) are also solutions of the equation. And the point (0,0) is not a solution at all.
How would I get the other two points?
Thanks in advance!
Your values are not correct. Give the solutions as pairs.
(√2, √2) is not a solution, but (√2, -√2) is.
(0,0) is not a solution. How did you get it? If you substitute x=y into one of the original equation, you will get the pair with √(2/3)
ehild
I got this:
y = \pm x
(x^2+x^2-4)(x+x)=0
x(x^2-2)=0
x = 0 \vee x=\pm \sqrt{2}
According to the solutions manual, which only states the values, not the method, the solutions are:
x = \pm \sqrt{2} \vee x = \pm \sqrt{\frac{2}{3}}
Oops... I see it now. I used f(x,y) instead of the partial derivatives.
I will try again!
Yes! I got it!
Thank you for your help, I appreciate it! :D
You see, it was worth to write it again...:smile:
ehild
  • · Replies 27 ·
  • · Replies 26 ·
