Find the difference in voltage at different points in a circuit.
2 replies · 4K views · last reply
Llamas
A section of a circuit XY shown below absorbs 50 W of power when a current I = 1.0 A passes through it as indicated by the arrow labeled i.
Circuit diagram of a section XY: terminal X connects to a zigzag resistor labeled 2 Ω, then to a rectangular element labeled C, then to terminal Y. An arrow above the wire labeled i points right. Caption: Figure 1: Problem 2.
(a) What is the voltage difference between X and Y?
(b) What is the voltage difference across element C?
V = IR
P = (V2)/R
P = (I2)R
I have answers for both parts, but I'm not confident about them.
(a) P = V2/R
R = V/I
P = V2/(V/I) = IV
Vx= P/I = (50 W) (1.0 A) = 50 V
P = I2R
I =[itex]\sqrt{P/R}[/itex]
Vy= IR = [itex]\sqrt{P/R}[/itex]*R = [itex]\sqrt{(50 W)/(2 Ω)}[/itex]*(2 Ω)
= 20V
Vx - Vy = 50 V - 20 V = 30 V
(b) Wouldn't it be 0? Why would the voltage change across the capacitor?
Edit: Maybe it's not a capacitor and I'm confused?
Thanks!
C is not a capacitor. It's just some "unknown circuit element", which is why it just appears as a block. (For one thing, look up the circuit symbol for a capacitor -- it is different).
To find the voltage across C:
- You know the voltage across both.
- You can find the voltage across the 2-ohm resistor using Ohm's law
- The voltage across element C has to be the difference between the above two voltages , since they are in series. In other words, the voltage across the 2-ohm resistor and the voltage across element C have to add up to 50 V.
Thanks!
For the second part, following your advice, I did:
Vc1 = IR = (1.00 A) (2 Ω) = 2 V
Vc1 + Vc2 = 50V
2 V + Vc2 = 50 V
Vc2 = 48 V
