Find the limit using taylor series
11 replies · 3K views
doktorwho
Using the taylor series at point ##(x=0)## also known as the meclaurin series find the limit of the expression:
$$L=\lim_{x \rightarrow 0} \frac{1}{x}\left(\frac{1}{x}-\frac{cosx}{sinx}\right)$$
3. The Attempt at a Solution [/B]
##L=\lim_{x \rightarrow 0} \frac{1}{x}\left(\frac{sinx-xcosx}{xsinx}\right)##
##L=\lim_{x \rightarrow 0} \frac{1}{x^2}\left(\frac{sinx-xcosx}{sinx}\right)##
I need help to continue. This is the first problem I am doing that asks me to claculate the limit using the taylor series. Am i suppose to write the taylor series for ##sinx,cosx## up to some element and somehow use them?
Yes. Keep the leading non-zero term in ##x## in both denominator and numerator. The rest will be irrelevant.
You may also find the series ##\frac{1}{1-z} = 1+z+z^2+z^3+\cdots## useful.
fresh_42 said:
Shorter is directly the series for cotangent.
Yeah, but who remembers that? :wink:
Wiki does. The advantage is, you don't even need a pencil.:smile:
So taylor for ##\sin(x) = x - \dfrac{x^3}{3!} + \dfrac{x^5}{5!} - \dfrac{x^7}{7!} ...## and for ##\cos x = 1 - \frac{x^2}{2!} + \frac{x^4}{4!}+...##
So:
##L=\lim_{x \rightarrow 0} \frac{1}{x^2}\left(\frac{(x - \dfrac{x^3}{3!} + \dfrac{x^5}{5!} - \dfrac{x^7}{7!} ...)-x(1 - \frac{x^2}{2!} + \frac{x^4}{4!}+...)}{x - \dfrac{x^3}{3!} + \dfrac{x^5}{5!} - \dfrac{x^7}{7!} ...}\right)##
So beside the x getting canceled in the upper part what else can i do?
So:
Do what @Orodruin has said: calculate the difference, multiply with ##\frac{1}{x^2}##, cancel the quotient such that leading term of the denominator equals ##1## and see which terms without an ##x## are left. (I haven't done it this way, though.)
Since the terms after ##\frac{x^3}{3!}## are getting smaller and smaller can i ignore them and write just the two leading members of the series?
Like:
##L=\lim_{x \rightarrow 0} \frac{1}{x^2}\left(\frac{(x - \dfrac{x^3}{3!}) -x(1 - \frac{x^2}{2!})}{x - \dfrac{x^3}{3!}}\right)##
##L=\lim_{x \rightarrow 0}\left(\frac{(x - \dfrac{x^3}{3!}) -x(1 - \frac{x^2}{2!})}{x^3}\right)##
##L=\lim_{x \rightarrow 0}\left(\frac{x^3}{3x^3}\right)=\frac{1}{3}##
Would this be correct?
Yes, it is correct. Mathematically one would have notated the missing terms like this: ##\; \sin(x)=x-\frac{x^3}{3!}+O(x^5)## instead of just dropping them, but the result is the same.
(##O(x^5)## means basically: "something with ##x^5## as factor".)
This is not quite right, and can sometimes lead to an incorrect answer (as it does in this example). If we keep only ##1-x^2/2## from ##\cos x## and just retain ##x## from ##\sin x## we get
$$\text{function} \doteq \frac{1}{x} \left( \frac{1}{x} - \frac{1}{x} + \frac{x^2}{2x} \right) = \frac{1}{2}.$$
This would lead to the incorrect limit 1/2.
However, if we keep ##x - x^3/6## from ##\sin x## we get
$$ \text{function} \doteq \frac{1}{x} \left( \frac{1}{x} - \frac{1 - x^2/2}{x - x^3/6} \right) = \frac{1}{3} + O(x^2),$$
giving the correct limit 1/3.
When we have cancellations (as in ##1/x - \cot x##) we should keep a couple of additional terms just to be sure that all the cancellations are properly accounted for, and so we get a correct constant term.
You misread me. I was referring to the expressions the OP had constructed with a common denominator. Clearly this does lead to the correct limit - as found by the OP.
If you want to be sure about it you should not be throwing terms at all but instead insert O(x^3). This will immediately tell you if you missed a term of a relevant order.
