Find the magnitude of the magnetic field 10 cm from the wire
The discussion focuses on calculating the magnitude of the magnetic field 10 cm from a wire carrying a current of 5 amps. The correct formula to use is B = μ₀I / (2πr), where μ₀ is the permeability of free space (4π × 10^(-7) T·m/A). After correcting the initial calculation, the accurate magnetic field magnitude is determined to be 7.96 × 10^(-7) T. The importance of simplifying the equation by canceling π is emphasized for ease of calculation.
  • Understanding of Ampère's Law
  • Familiarity with the concept of magnetic fields around current-carrying wires
  • Knowledge of the permeability of free space (μ₀)
  • Basic algebra for manipulating equations
  • Study the derivation of Ampère's Law and its applications
  • Learn about the effects of different current values on magnetic field strength
  • Explore the concept of magnetic field direction using the right-hand rule
  • Investigate the impact of distance from the wire on magnetic field intensity
Physics students, electrical engineers, and anyone interested in electromagnetism and magnetic field calculations.
Covenant32
A) Find the magnitude of the magnetic field 10 cm away from the wire at point P as shown in the picture. The current is directed along the x-axis.
B) Find its direction
Info: I = 5 amps. Point P lies on the Y-axis. Current on the X-axis.
Picture (I have drawn): http://twitpic.com/7e0l7e
I THINK: B=u*I/2*pi*r
B = (4pi * 10^(-7)) * 5/2 *pi * .1m = 7.85 * 10^(-8) N
***I am not sure if this is correct. I have no means to check my work, so I am hoping someone can simply tell me whether or not I am correct, and if not, perhaps enlightening me as to which direction I should head to find the right answer. Much thanks.
Better to write it like this:
B = \frac{\mu_0 I}{2 \pi r}
Redo your calculation.
Thank you, Doc Al. I redid my calculation in that format and got 7.96E-7. Does that seem correct?
Again, thank you.
Not exactly. When you plug in the value of μ0 = 4*pi*10^(-7), that pi will cancel with the pi in the denominator. So you should be able to do the entire calculation without touching a calculator.
Try it one more time. :smile:
Aaah, got it. That should've been evident from the beginning. :redface: Thank you, Doc Al. You have alleviated me some frustration. :smile:
