Find the max and min value from equation?
13 replies · 2K views · last reply
Helly123
f ' (x) = 0 --> to find extreme points
## 2x^2 + y^2 = 4##
## y = \sqrt{4 - 2x^2}##
## y ' = \frac {-2x} {\sqrt{4-2x^2}} ##
## 0 = \frac {-2x} {\sqrt{4-2x^2}} ##
x = 0
also ## 4 - 2x^2 >= 0 ##
## 4 >= 2x^2 ##
## \sqrt{2} >= x ##
## x <= +/- \sqrt{2} ##
## x= -\sqrt{2} , x = 0, x = \sqrt{2} ##
## f( -\sqrt{2} ) = 0 ## --> ##4x + y^2 = -4\sqrt{2}## --> min
## f( \sqrt{2} ) = 0 ## --> ##4x + y^2 = 4\sqrt{2}## ---> max
## f(0) = 2 ## --> ##4x + y^2 = 4##
is there something wrong?
I suppose so.
You manipulate things, but where does this ##f(x)## appear ?
Setting ##y ' = \frac {-2x} {\sqrt{4-2x^2}}=0## finds you extrema for y(x) at x = 0 (you recognize this is an ellipse ?) but that is not what you want!
## 2x^2 + y^2 = 4##
x = 0
You aren't using the fact that the points have to lie on the given ellipse.
You don't need calculus to solve this problem. In the equation of the ellipse, solve for y, and then substitute that into the expression whose max and min values you want to find. I get a maximum value of 6.
## 4 >= 2x^2 ##
## \sqrt{2} >= x ##
I get what you're trying to say, but this is not how to say it. It should be
##-\sqrt 2 \le x \le \sqrt 2##
So did I but I didn't want to spoil the fun.
And with calculus you can find maxima, minima and flexing points (is that the proper designation?), but on ##[0,1]## the function ##f(x) = x## has a lowest value of 0 and a maximum value of 1 and neither can be found with calculus !
Usual term is "inflection point".
However, noting that the derivative is constant and positive, one can conclude that the minimum occurs at the left endpoint of the interval, and the maximum occurs at the right endpoint of the same interval.
Thanks !
Back to Helly: do you now see what needs to be done (calculus or not) ?
## 2x^2 + y^2 = 4##
##\frac{x^2}{2} + \frac{y^2}{4} = 1## -> ellipse equation
y = 0
## x = \sqrt{2} \ or -\sqrt{2} ##
x = 0
## y = 2 \ or -2 ##
x = 0
## y^2 = 4 ##
## 4x + y^2 = 4 ##
y = 0
## x = 4\sqrt{2} \ or -4\sqrt{2} ##
## 4x + y^2 = 4\sqrt{2} \ or -4\sqrt{2} ##
What do you mean solve for y?
Helly123 said:
## 2x^2 + y^2 = 4##
Express y as function of x.
## y = \sqrt 4 -2x^2 ## this is y as function of x
how to solve it?
## 0 = \sqrt 4 -2x^2 ##
##4 - 2x^2 = 0##
x = -2 or 2
what am I supposed to do? using calculus?
BvU said:
Thanks !
no...
y = \sqrt 4 -2x^2
## ? You sure or is this a ##\TeX##typo and you forgot the curly brackets { } around the argument for ##\sqrt {}## ?
Good. Now you can substitute y in the function for which you want to find the maximum and the minimum value
Helly123 said:
how to solve it?
You can not solve one equation for two unknowns -- 'solve' in the sense I seem to have let you think. The sense I meant it is as Ersbeth posted (you can accept my apologies, but I think it's better if you get used to the slight ambiguity :smile:)
To help speed up things somewhat: now that you have ##y^2## as a function of ##x##, you can investigate the function ##4x+y^2## on the domain you found for ##x## -- using calculus or common sense :rolleyes:PS:
Helly123 said:
x = -2 or 2
tut tut ! What did you find in post 7 ? (the first time y=0, that is)
##2x^2 + y^2 = 4##
max and min of ## 4x + y^2? ##
Answer
## y = \sqrt{4 - 2x^2} ##
domain is
## 4 - 2x^2 >= 0 ##
so we get ## -\sqrt{2} < = x < = \sqrt{2} ##
now, question is ## 4x + y^2 ## max and min?
from equation ## 2x^2 + y^2 = 4 ## we get ## y^2 = 4 - 2x^2##
substitute ## y^2 = 4 - 2x^2 ## to ## 4x + y^2 ##
## 4x + y^2 = 4x + 4 - 2x^2 ##
## f(x) = 4x + 4 - 2x^2 ##
## f ' (x) = 4 - 4x ##
0 = 4 - 4x
x = 1 -> satisy domain
check x = 1, and x in domain for ## 4x + y^2 = 4x + 4 - 2x^2 ##
x = 1
## 4x + y^2 = 4 + 4 - 2 = 6 ##
x = ## -\sqrt{2}##
## 4x + y^2 = -4\sqrt{2} ##
x = ## \sqrt{2}##
## 4x + y^2 = 4\sqrt{2} ##
max = 6
min = ## -4\sqrt{2} ##
is the concept right? I'm lack at concept... I manipulate formula to get answer I want.
oh that's substitute the y^2 to ##4x+y^2## right
Yes. Well done.
One pedantic remark: you used calculus to find the maximum. As Mark said in #3, you indeed don't really need it. Can you see how ?
:smile: that's what we all do !
BvU said:
Yes. Well done.
hmm.. I get it.
##4x + 4 -2x^2##
change it to another form
##4x + 4 -2x^2 = -2(x^2 - 2x) + 4 ##
##= -2(x^2 - 2x + 1) + 2 + 4 ##
##= -2(x-1)^2 + 6 ##
so ##4x + y^2 = -2(x-1)^2 + 6 ##
max at 6, when x = 1
