Find the missing force when the boy is pulled
  • Thread starter Thread starter issacnewton
    Force
35 replies · 4K views
issacnewton
A 15.0 kg boy sits on a 2.00 kg stake board and is pulled forward by his parents. His mom pulls with a force of 100. N at an angle of 35 degrees and the boy and skate board accelerate along the x-axis at 8.50m/s2? a. What is the magnitude and direction of the father’s force if the boy and skate board move along the x axis? b. How far would they get if they started from rest and the parents pulled for 4.00s?
Newton's law
Let ##F_2 = 100 N## be the force exerted by the Mom and ##F_1## be the force exerted by the dad and let ##\theta## be the angle made by this with the horizontal. Let ##m## be the mass of the boy + stake board. The we have weight ##mg## and the normal reaction upward ##N## acting on boy+board system. We can set up the following equatons.
$$ F_1 \cos(\theta) + F_2 \cos(35) = ma$$
$$ 0 = N + F_2 \sin(35) + F_1 \sin(\theta) - mg$$
Now ##a## is also given, so we have 2 equations and three unknowns, ##F_1##, ##\theta##, and ##N##. So how would we solve this ?
This problem only makes sense to me if the x and y axes are two horizontal axes. We aren't considering vertical components at all. The father's vertical component could be anything that's not enough to accelerate the boy upward. Thus, the angles are horizontal angles relative to the forward direction, not vertical angles.
So under that assumption, ##F_2 \sin(35) + F_1 \sin(\theta) = 0##.
so what happens to ##N## and ##mg##. That is also part of the free body diagram.
Orodruin, why would N = mg ? Because of ##F_1## and ##F_2##, the normal reaction is not necessarily equal to the weight.
but force applied by the mom is at 35 degrees with the horizontal and question is asking to find father's force magnitude and its direction. So if we assume that parents forces are horizontal, then question does not make sense.
No it is not. This is your interpretation (in which the problem statement does not make sense) not the statement of the problem. The formulation that makes sense is that the 35 degrees is 35 degrees relative to the direction of acceleration, but still in the horizontal plane.
acceleration is in the positive x direction. So you are right that ##F_1## makes angle 35 with the horizontal direction of the acceleration a. And that's what I was saying when I said that mom's force is at 35 degrees with the horizontal.
There are two horizontal directions. One which is the direction of the acceleration and one more, which is perpendicular to it.
ok, I take upward direction here as vertical direction and not the horizontal direction. So are you and me saying the same thing ?
Ok, let me put a free body diagram, otherwise we will be talking past each other. Is that FBD correct ?
Newton's law
I would stick with the first equation. Remember that acceleration on the right hand side is that caused by the net force, which in this case is in the x direction.
You should separate by components.
By components, I mean in the x and y direction.
bluejay27, I have two equations in my original post. One for x direction and other for y direction. So ##F_1 \cos(\theta)## would be the x component of the force ##F_1##. I realize that I have interchanged the forces ##F_1## and ##F_2## in the free body diagram. Sorry about that.
Orodruin, are you saying that both the forces are acting along the positive x direction ? Then what is 35 degrees referring to ?
I would just solve for the force of the dad. Since the sum of the forces are already restricted in the direction of x. For the magnitude and direction of the force of the dad, you can now use the sum of the forces in the y direction.
of course the motion is only in the horizontal direction, but ##F_2## has component in the vertical direction. And we can't assume that ##F_1## is acting only in the forward direction.
Solve for the unknown force of x. Then solve for the unknown force of y. Only use the mass of the boy when solving in the y direction. You will then be able find the magnitude and angle with Fx and Fy of the dad by forming a triangle.
If we assume that ##F_1## and ##F_2## are in the horizontal plane, then ##N = mg## and is irrelevant.
Yes, it would because we are saying that there is no vertical component of ##F_1## and ##F_2##. If ##x## is East, then the mother is pulling northeast and the father is pulling southeast.
The problem didn't say that explicitly, didn't say whether those angles are vertical angles or horizontal ones. But for the reasons you gave, the problem doesn't make sense if they are vertical angles. As I said in my initial response, the problem only makes sense if all the forces and angles are in the horizontal plane.
Orodruin is completely right. If we are to solve this confusion, we must realize that:
1. There are three directions, which I will call here, x, y (both in the horizontal plane) and the vertical direction, which we can call z.
2. The original statement of the problem does not make point 1 clear, which is the driving force behind the confusion.
3. The problem can be solved if we follow what Orodruin is saying. Both forces are in the horizontal plane. The angles given are therefore angles in the horizontal plane. N = mg will then be correct, but irrelevant to the problem because both N and mg are along the vertical (z) direction.
Imagine the boy is in a harness with a loop onto which the pulling ropes are attached so that Mum can pull one rope and Dad the other. Mum's rope is at 35 degrees to the direction of motion and Dad's at unknown θ. The cos components of the rope tensions provide the forward force whilst the sine components presumably cancel so that the boy does not move sideways. Both ropes are in the same horizontal plane as the loop to which they are attached. I think this is what Oordruin is indicating when he says there are no vertical force components other than mg and N.
Oh. Now I see what you mean. Now if I solve it, then I get ##\theta = 35## degrees and dad's force is ##F_1 = F_2 = 100 N##. Is that right ?.
But the problem is really confusing. It should explicitly tell the student what the question is talking about.
What if the mother - also a superhero - doesn't want her child to get windburn, and is actually pulling backwards against the father's overenthusiasm, that ends up pulling them along at ##8m/s^2## for 4 seconds.
Make reasonable assumption(s), state them, then you can solve the problem.
In this case the reasonable assumptions for a mildly boring answer are that the parents' pulls are both positive along the ##x## axis, cancel each other out on the ##z## axis, and don't exceed the force of gravity acting on the child, on the ##y## axis. Also, the ##35°## of the mother's pull is off the x-axis.
IssacNewton said:
Now if I solve it, then I get θ=35\theta = 35 degrees and dad's force is F1=F2=100NF_1 = F_2 = 100 N. Is that right ?
And that doesn't strike you as being a little bit too easy ?
Okay, ignore the possible ##y## axis component (though you really should do that for fun, separately), and assume that both pulls are entirely on the ##xz## (horizontal) plane.
Show your work.
Let me try. Picture a coordinate system with all three axes x, y, and z. X points east, y points north, and z points up. What Orodruin is trying to tell you is that the problem is in the x y plane. There is no up. The angle refers to the angle from the x axis. Mom is pulling North of east. In order for the boy to move East Dad must pull south of east. The two dimensions give you two equations and so you can solve for both the magnitude and direction of Dad’s force.
Regarding N=mg, that does not act in the x y plane. Also skateboard = “no friction”, so all you have are mom’s and dad’s forces and inertia.
