Find the probability of a particle in the left half of an Infinite Square well
The discussion focuses on calculating the probability of a particle in the left half of an infinite square well, specifically using the wavefunctions defined as ##\psi_n(x)=\sqrt{\frac {2} {a}} \sin(\frac {n\pi x} {a})##. Participants explore various methods, including direct integration and Dirac notation, to simplify the calculation. A key insight is the symmetry of the wavefunctions, leading to the suggestion that the hint provided may contain a typographical error regarding the relationship ##\psi_n(x) = \psi_n(a-x)##. This symmetry can be leveraged to simplify the integration process.
  • Understanding of quantum mechanics, specifically infinite square wells
  • Familiarity with wavefunctions and their properties
  • Knowledge of Dirac notation and its application in quantum mechanics
  • Proficiency in calculus, particularly integration techniques
  • Study the properties of wavefunctions in quantum mechanics, focusing on normalization and symmetry
  • Learn about Dirac notation and its applications in quantum mechanics calculations
  • Practice integration techniques for functions involving sine and cosine
  • Explore the implications of boundary conditions in quantum systems, particularly in infinite potential wells
Students and professionals in physics, particularly those studying quantum mechanics, as well as educators looking to enhance their understanding of wavefunction properties and integration techniques in quantum systems.
Moolisa
Image of problem in Attempt
At t = 0, a particle of mass m in an infinite square well with walls at
x = 0, x=a, is in a superposition of the (normalized) first and third stationary states
##\Psi(x,0)=A(2\psi_1(x)-i\psi_3(x))##
(a) What must A be in order for Ψ to be a normalized wavefunction?
##A=1/\sqrt5##
(b) What is the probability that the particle is in the left half of the box
(i.e.,between x = 0 and x = a/2) at t = 0?
Hint: Instead of trying to do a complicated integral directly, notice that for odd n,##\psi_n(x)=\psi_n(a-x)~\text{for}~0\leq x\leq a~\text{ You can use this to relate} \int_0^{{a/2}} \psi^*_m\psi_n\, dx~to\int_0^{{a}} \psi^*_m\psi_n\, dx~\text{when m, n are both odd.}##
Question 1: Is it possible to do this in a simpler way? Perhaps using dirac notation?
Question 2: How do I use the hint
Stationary state of an infinite square well
##\psi_n(x)=\sqrt{\frac {2} {a}} ~~ sin(\frac {n\pi x} {a})##
Attempt: I'm sure I know how to do this the long way using the definition of stationary states(##\psi_n(x)=\sqrt{\frac {2} {a}} ~~ sin(\frac {n\pi x} {a})## and ##\int_0^{{a/2}} {\frac {2} {a}}(1/5)\left[~ \left(2sin(\frac {\pi x} {a})+i~ sin(\frac {3\pi x} {a})\right)\left( 2sin(\frac {\pi x} {a})-i ~sin(\frac {3\pi x} {a})\right)\right]dx ## then combining and using trig identities then integrate
But
Assuming my A is correct, I actually have 2 questions about part (b). One is about how to use the hint, the other if it is possible to find this using another method
I tried ##1/5\langle \Psi|(2\psi_1-i\psi_3)|\Psi\rangle##
If this is possible and the correct set up, how do I continue? Do I try to separate them? We just learned this week, so I am still pretty confused about it
If not possible to use, why?
Question 2: How can I use the hint
I want to understand how to do it according to the hint, if I use the hint does this mean
##\int_0^{{a/2}} {\frac {2} {a}}(1/5)\left[~ \left(2sin(\frac {\pi (x-(a/2))} {a})+i~ sin(\frac {3\pi (x-(a/2))} {a})\right)\left( 2sin(\frac {\pi (x-(a/2))} {a})-i ~sin(\frac {3\pi (x-(a/2))} {a})\right)\right]dx ##
I'm assuming this is wrong because I don't see how this makes it any simpler unless I'm missing something crucial
x = 0
Where is the 2nd wall? Or is it at infinity? Sorry, your statement is a bit confusing to me...
Sorry, I should have been more careful!
Walls are at x=0 to x=a
Set up the integral for the probability integral using ##\psi_1## and ##\psi_3## without substituting the actual forms of those wavefunctions. Multiply out the parentheses to get a sum of integrals.
I think the hint has a typographical error, and it should read "##\psi_n(x) = \psi_n(a-x)##". It's a statement about the symmetry of those wavefunctions. Using the complete hint, you should be able to change the limits on the integrals and put them in a form that you can write down the values immediately without having to plug in the wavefunctions and grind them out. Hint: the wavefunctions are normalized!
  • · Replies 39 ·
13K
