Find the probability that E' occurs at least once
  • Topic:
  • Thread starter Thread starter mathlearn
    Probability
7 replies · 3K views · last reply
mathlearn
Data
Below are the possible observations of a random experiment in a tree diagram.Each time it is observed whether the event E defined in part i occurs or not.
View attachment 5990Where do I need help
Many Thanks :)
mathlearn said:
Data
Many Thanks :)
Hey mathlearn!
The probability that E' occurs at least once is 1 minus the probability that E' never occurs.
What is the probability hat E' never occurs? (Wondering)
I like Serena said:
Hey mathlearn!
$\frac{5}{9}*\frac{5}{9}=\frac{25}{81}$
Now to proceed? Subtract 1 from both sides?
Here's a way to look at why ILS pointed you to find the probability that E' never occurs, that is, to use the complement:
We know it is certain that either E' never occurs (we'll call that event A) OR E' occurs at least once (we'll call that event B and this is what we are trying to find). We may state this mathematically as:
$$P(A)+P(B)=1$$
Since we are trying to find $P(B)$, let's arrange this as:
$$P(B)=1-P(A)$$
You've already found $P(A)$, so plug that in and then simplify to get $P(B)$.
Sometimes it's simpler and more efficient to find the complement, and use the complement rule, instead of computing the required probability directly. :D
$$P(A)+P(B)=1$$
$$P(B)=1-P(A)$$
$\displaystyle P(B)=1-P(A)$
$\displaystyle P(B)=1- \frac{25}{81}$
$\displaystyle P(B)=\frac{81}{81}- \frac{25}{81}$
$\displaystyle P(B)=\frac{56}{81}$
Correct ? :rolleyes:
Well, let's check your answer by computing the probability directly...
$$P(B)=\frac{5}{9}\cdot\frac{4}{9}+\frac{4}{9}\cdot\frac{5}{9}+\frac{4}{9}\cdot\frac{4}{9}=\frac{20+20+16}{81}=\frac{56}{81}\quad\checkmark$$
You see, by using the complements rule, you only had to analyze one path in the tree diagram, whereas when I computed the probability directly, I had to analyze three paths.
(Party)(Party)(Happy) Perfectly explained! Thank you very much MarkFL & I Like Serena.
Can $\displaystyle P(A)+P(B)=1$ be replaced with $\displaystyle P(E)+P(E')=1$ if necessary?
As long as you know what your symbols stand for, then what you choose is fine. (Yes)
