Find the result of definite integration
  • Thread starter Thread starter songoku
6 replies · 3K views
songoku
Find ##\frac{2}{L} \int_{0}^{L} \sin\left(\frac{5x}{L}\right) \sin \left(\frac{n\pi x}{L} \right) dx##
Trigonometry Identity
Integration
$$\frac{2}{L} \int_{0}^{L} \sin\left(\frac{5x}{L}\right) \sin \left(\frac{n\pi x}{L} \right)dx$$
$$=\frac{2}{L} \int_{0}^{L} \left(\frac{1}{2} \cos\left[\left(\frac{5-n\pi}{L}\right)x\right] -\frac{1}{2}\cos \left[\left(\frac{5 + n\pi}{L} \right)x\right]\right)dx$$
$$=\frac{1}{5-n\pi} \sin (5-n\pi)-\frac{1}{5+n\pi}\sin(5+n\pi)$$
This is as far as I can get but the answer key is if ##n=5## then the result of integration is 1 and will be zero for other values of ##n##.
How to proceed to get the answer? Thanks
songoku said:
Homework Statement: Find ##\frac{2}{L} \int_{0}^{L} \sin\left(\frac{5x}{L}\right) \sin \left(\frac{n\pi x}{L} \right) dx##
Are you sure there's not a factor of ##\pi## missing in that expression? I think it should read:$$\frac{2}{L} \int_{0}^{L} \sin\left(\frac{5\pi x}{L}\right) \sin \left(\frac{n\pi x}{L} \right) dx$$
No, in the original question there is no ##\pi##
But let say if there is ##\pi##, then the integration becomes:
$$=\frac{1}{5\pi-n\pi} \sin (5\pi-n\pi)-\frac{1}{5\pi+n\pi}\sin(5\pi+n\pi)$$
In this case, ##n## can not be 5 because one of the denominator will become 0 and for other value of ##n## (sorry I forgot to put that ##n## must be positive integer) the sin term will be zero. Still does not match the answer key for ##n=5##
Thanks
EDIT: I just realize the numerator of the first term is also zero. Does it mean I have to use limit as ##n## approaches 5 to find the value of the first term? I tried and the result is 1
Correct.
Well then there's definitely a typo in the original homework statement. And yes, your limit approach gives the correct answer for ##n=5##. But you can also get the correct result by setting ##n=5## in the integrand before you do the integral. Try it!
When you divide by something, you must always specify that something is not zero. For example:
$$\int \cos(nx) \ dx = \frac 1 n \sin(nx) + C \ (n \ne 0)$$In this case, if ##n = 0##, then:
$$\int \cos(nx) \ dx = \int 1 \ dx = x + C$$
Ah I see. Since I need to divide by ##5\pi-n\pi##, I need to realize this is for the case where ##n\neq 5##. The case ##n=5## must be done separately.
Thank you very much for the help and explanation renormalize, Gavran, PeroK
