Find the second largest integer in a Java array
  • Context: Comp Sci
  • Thread starter Thread starter bc030400412
    Array Java
2 replies · 23K views
bc030400412
Q1. Write a function that accepts an array of integers and returns the second largest integer in the array. Return -1 if there is no second largest.
The signature of the function is
public class ID
public static void main(String[] args){ }
int f(int[ ] a) { }
Examples:
if the input array is {1, 2, 3, 4} then return 3
if the input array is {{4, 1, 2, 3}} then return 3
if the input array is {1, 1, 2, 2} then return 1
if the input array is {1, 1} then return -1
if the input array is {1} then return -1
if the input array is {} then return -1
Ok, you have the signature, what about the actual code?
The examples you've given doesn't demonstrate you've attempted the program. Anyone can pick the second largest number in a set. Please show us some code.
public static void main(String[] args) {
// TODO code application logic here
int secondlargest= -1;
int largest = -1;
int number[] ={4, 1, 2, 3};
for (int i=0;i < number.length;i++)
if(largest < number )
secondlargest = largest;
largest = number;
if(secondlargest < number && largest != number )
secondlargest = number;
System.out.println(secondlargest);
//System.out.println(largest);
// System.out.println(objhwa.data); // Display the string.
