Find the Sum of The Geometric Series
The discussion focuses on finding the sum of the geometric series defined by the formula Ʃ(1 to infinity) (2/3)^(3n). The series converges using the formula a/(1-r), where 'a' is the first term and 'r' is the common ratio. The user initially struggles with manipulating the series into the standard form ar^n-1 due to the starting index being 1 instead of 0. The final conclusion is that adjusting the index allows for the correct application of the formula, leading to the sum of 8/19.
  • Understanding of geometric series and convergence
  • Familiarity with the formula a/(1-r) for series summation
  • Ability to manipulate series indices
  • Basic algebra skills for simplifying expressions
  • Study the manipulation of series indices in geometric series
  • Learn about convergence criteria for geometric series
  • Explore examples of geometric series with different starting indices
  • Practice solving geometric series problems using the formula a/(1-r)
Students studying calculus, mathematics educators, and anyone looking to deepen their understanding of geometric series and series manipulation techniques.
forestmine
For a geometric series, the series converges to a/1-r
I'm really just confused about how to manipulate this so that it has a form of ar^n, especially since it starts at 1 rather than 0. I know that since the series starts at 1, we ought to have it in the form ar^n-1, but I'm at a loss as to how to go about.
I'm not really concerned with the answer so much as how one would go about getting it, and really understanding the process. It seems I'm having a hard time figuring out how to manipulate series and get them in the correct forms...
Any help in the right direction would be great. Thanks!
This is what I've come up with, but I'm not sure if it's correct...
We can rewrite the series as ((2/3)^3)^k = (8/27)^(k-1) * (8/27)
a = 8/27
r = 8/27
Computing a/1-r, I get 8/19...
Well, to fix the index problem, try just changing the index from 1 to 0 on your sum, and then subtracting off whatever you added to put the series in the correct form. Then the total sum should remain unchanged.
Thanks, I think I got it. I just get totally thrown off when the index isn't in the correct form, or when the series is blatantly obvious, haha.
Thank you, though!
The beginning index doesn't matter. In the sum ##\frac a {1-r}##, ##a## represents the first term, whatever it is with the starting index and ##r## is the common ratio. What did you get for ##r##?
