Find the value of x using the Lambert W function
  • Thread starter Thread starter chwala
    Function Value
18 replies · 4K views
chwala
I got this problem from wikipedia, the problem is on the attachment.
Solve the equation ##3^x=2x+2## using the Lambert W function.
Lambert W function
it really took me time to figure out as to how that equation in aterisk was arrived at...i just noted that both sides of the equation were multiplied by ##-\frac {1}{3}## any particular reason for that? what is the common thinking around that? can one multiply both sides by say ##\frac {1}{6}##? i am encountering this lambert for the first time and i really want to understand how it works...i would appreciate guidance leading to solution. Can one use the ti nspire to find the Lambert W value, in reference to the very last step leading to ##-0.79011## and ##1.44456##?
In the following step we have,
let##y=3^{-x-1}##
##ln y=(-x-1)ln 3##
##e^{(-x-1)ln3} = y##
therefore on substituting back we get,
##(-x-1)e^{(-x-1)ln3}=-\frac {1}{6}## ...note that we get the desired form ##we^w##
multiplying both sides by ##ln 3## yields,
→##ln 3 (-x-1)e^{(-x-1)ln3}=-\frac {1}{6}####ln 3##
this steps are clear no problem here, the next step i would like some input...
i could as well say,
##(x+1)3^{-x}=\frac {1}{2}##
on multiplying both sides by ##-\frac {1}{9}## we have,
##(-x-1)3^{-x-2}=-\frac {1}{18}##
it follows that, as in the previous example, after taking natural logs...
##(-x-1)e^{(-x-2)ln 3}=-\frac {1}{18}##
##ln 3 (-x-1)e^{(-x-2)ln 3}=-\frac {1}{18}ln3##
which is in the desired form of ##we^w##...this is perfectly understood...looks like one has to consider the powers of ##3## ie ##3^1, 3^2 ... 3^n##
what is remaining is to understand how they found the solution to the problem and secondly, if my approach would give an equivalent or rather correct solution...
i just checked this...this will not be the right approach since we do not get the desired form ##we^w##
chwala said:
Homework Statement:: I got this problem from wikipedia, the problem is on the attachment.
Relevant Equations:: Lambert W function
I noted that we can only multiply in powers of ##3## just to answer my own question, we can not therefore, think of multiplying both sides by ##\frac {1}{6}##
I came up with another equation that is my own ...
consider ##4^x=6x+6##
→##(-x-1) 4^{-x}=-\frac {1}{6}##
→##(-x-1)4^{-x-1}=-\frac {1}{24}##
→##(-x-1)ln 4 e^{(-x-1)ln 4}= -\frac {ln4}{24}##...this is correct as we are getting the desired form of ##we^w##
→##(-x-1)ln 4=W_{0} [\frac {-ln4}{24}##].....a
→##ln 4(-x-1)=W_{-1} [\frac {-ln4}{24}##]....b
i am trying to demonstrate the fact that i am now conversant with the approach...i just need to know how to deal with the last part ##a## and ##b## cheers
fresh_42 said:
Have you checked your results with WolframAlpha? They say it's ##x=-\dfrac{1}{\log 3}\left(W_n\left(-\dfrac{\log 3}{6}\right)+\log 3\right)##.
You can also use the series expansion to calculate the value, see
https://en.wikipedia.org/wiki/Lambert_W_function
Fresh is the solution shown on wolframalpha different from the solution that was shown on Wikipedia?ie on post ##1##
I haven't checked what you have written as it is a bit difficult to read. In any case your numbers ##18## and ##\log 4## didn't look right. Post #2 started well, but why do you want to divide by ##9##?
Let's see how I would start: If we substitute ##y=x+1## then we get ##6y=3^y##. With ##u=y \log 3## we get ##e^u## on the RHS and ##cu:=\dfrac{6}{\log 3}u## on the LHS which is almost what we are looking for: ##\dfrac{1}{u}e^u=c##. Next try ##v=\dfrac{1}{u}## and so on.
At the end, you should find one substitution for ##y## instead of three and write it down systematically.
Maybe you didn't have time to look at my post...I was asking if it would be correct ...following the example on Wikipedia. I have though taken consideration of your input...thanks
Post #2 looks good. But you made a mistake: it isn't ##e^{-2-x}\ln 3##. It has to be ##e^{(-2-x)\ln 3}## which makes the rest going wrong.
Typo error aaaaargh ...can I go ahead and amend that?
Sure. But you will get a multiple of ##x## so you will probably need a ##w=ax+b## substitution of so.
I am really not getting what you are saying. Look at the original post ##1##. My post ##2## and ##3## is simply an exact repetition of post ##1##. I wanted to know if ##3## is correct as I used a different factor ...What i simply wanted to know is how the author arrived at the solutions of ##-0.79## and ##1.44## that is the only part I would like to understand.
Post ##5## is my own created problem,...I was simply trying to follow post ##1## in order to solve it. I hope this is clear, I just made some typo errors but my working is correct.
Sorry, I ignored the picture in post #1, because I thought it is from a book and I normally ignore any photos, because they are hard to read and my eyesight isn't what it was anymore.
Yes, these seem to be correct. WolframAlpha only confirmed the ##W_1## solution, so I could only take the graph to check the ##W_0## solution, but it looks o.k.
:cool: sorry, I should have indicated the source of the question. The source is Wikipedia.
i just amended my equations, kindly help me arrive to the solution for my post number ##5##
It looks o.k. to me. At this point I would do one of the following:
  • look at WolframAlpha for the general solutions and the graph
    https://www.wolframalpha.com/input/?i=4^x=6x+6
  • draw the W-function graph on your own and solve the problem how to find x graphically
  • take the series for the W-function, e.g. from Wikipedia, plug in the value -ln 4 / 24 and calculate the result as long as you get the precision that you want
Thanks I will definitely look at it...cheers goodnight
fresh thank you, ...it means that we have to use the computer software to finally calculate the solution...
