MHB How Long to Empty Lake Erie with a Cone Cup?
The discussion centers on calculating the time required to empty Lake Erie, which holds 116 cubic miles of water, using a cone cup with a diameter of 2.75 inches and a height of 4 inches. The volume of the cone is calculated to be approximately 7.9194 cubic inches. By determining the total volume of Lake Erie in cubic inches and dividing it by the volume of the cone, the number of cone fillings needed is established. Multiplying this by the time taken to dump one cone (2 seconds) provides the total time to empty the lake.
  • Understanding of stoichiometry
  • Knowledge of volume calculations for geometric shapes
  • Familiarity with unit conversions (inches to feet, miles to inches)
  • Basic arithmetic skills for large number calculations
  • Research volume calculations for different geometric shapes
  • Learn about unit conversion techniques in mathematics
  • Explore stoichiometry applications in real-world scenarios
  • Investigate variations in the problem, such as changing the number of cups dumped per time interval
Mathematicians, educators, students studying geometry and stoichiometry, and anyone interested in large-scale volume calculations.
kato1
Lake Erie holds 116 cubic miles of water. Suppose you start dumping out the entire volume of Lake Erie using a cone cup. A typical cone cup has a diameter of 2.75 inches and a height of 4 inches. About how long would it take you to empty the lake if you could dump out one cup per 2 seconds? Use stoichiometry.
Work:
1 foot = 12 inches
1 mile = 5280 feet
1 cubic foot = 1728 cubic inches
1 cubic mile = 1.4720 x 10^11 cubic feet
1 cubic mile = 2.536 x 10^14 cubic inches
radius= 2.75/2= 1.375 inches
Volume of cone= h/3*(pi)r^2
= 4/3*(pi)(1.375)^2
= 7.9194 in^3
5280 ft/1 mile * 12 in/1 ft = 63,360 in/miles
Volume of Lake= 116 cubic miles * 63,360^3
=4.6568 * 10^11 cubic inches/miles
Note: I'm unsure how to find the time in this problem. Also, I'm not sure if my work above is correct. Thank you.
Mathematics news on Phys.org
I have not checked your arithmetic but assuming it is correct dividing the volume of the lake by the volume of the paper cone gives the number of times you would have to fill the cone from the lake (I will try not to become distracted by wondering where you are going to dump the water!). You are told that you dump out one cone of water every 2 seconds so multiplying the number of times you need to dump out a cone by 2 gives the number of seconds it takes.
This is a bit of a stretch but do you know how the problem would differ if you had to dump out three cups per two seconds rather than one cup per one second.
  • · Replies 30 ·
