Finding 2 of 3 Forces Given 1 and a Resultant
The discussion focuses on solving for the magnitudes of Force B and Force C given Force A and the resultant force in a vector addition problem. Force A has a magnitude of 200 lb at an angle of 35° N of W, while the resultant force is 260 lb at 85° S of W. The equations used include vector component breakdowns: Rx = Acos35° + Bx + Cx and Ry = Asin35° + By + Cy. The final estimated values for Force B and Force C are approximately 1780.15 lb and 2006.18 lb, respectively, confirming the correct application of vector addition principles.
  • Understanding of vector addition and components
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of force representation in physics
  • Ability to solve simultaneous equations
  • Study vector addition techniques in physics
  • Learn about resolving forces into components
  • Explore trigonometric identities and their applications in physics
  • Practice solving simultaneous equations with two unknowns
Students studying physics, particularly those focusing on mechanics and vector analysis, as well as educators looking for examples of force resolution and vector addition problems.
cadcdac
Force A has a magnitude of 200lb and points 35° N of W. Force B points 40° E of N. Force C points 30° W of S. The resultant of the three forces has a magnitude of 260lb and points 85° S of W.
(a) What is the magnitude of Force B?
(B) What is the magnitude of Force C?
F = √(Fx2 + Fy2)
Fx = FcosΘ
Fy = FsinΘ
where
F = Force
Θ =Angle
Having drawn these vectors, I've been trying to use components which could've been easier if 2 forces were given.
Resultant's X = Rx = 260cos85°
Resultant's Y = Ry = 260sin85°
Force A's X = Ax = 200cos35°
Force A's Y = Ay = 200sin35°
Bx = Bsin40°
By = Bcos40°
Cx = Csin30°
Cy = Ccos30°
And formed equations
R = A + B + C
With these, I don't really know because 2 are missing while having no other equations for them like A+B=1 or stuff like that that give hints. Seems like something is missing, but i don't know because others have solved it. Don't know what is next.
Hello cad, welcome to PF :smile: !
You have two unknows (B and C) and two equations.
You are making life difficult for yourself by dragging in Bx, y and Cx, y.
[edit]By the way, I hope you don't mean R = A + B + C but ##\vec R = \vec A + \vec B + \vec C## :rolleyes:
So 260 = 200 + ##\vec B + \vec C## would be the first equation and i'll have to find the other equation
By any chance, does the 2nd equation contain angles in it? Or anything?
Ah yes, sorry about that
260 and 200 are not vectors. I take it you do know about vector addition ?
You have two equations
with two unknowns: the magnitudes B and C.​
Perhaps I confused you with my blunt comment
but the intention was that you would substitue the magnitudes of B and C
I see. I came up with estimated answers B = 1780.15 and C = 2006.18. I also checked and resulted to 259.99... Am I doing this right?
Does it match with the drawing you mentioned in post #1 ?
Check your angles. Do they have the same reference ?
In math and physics, east is zero angle, north ##\pi/2##
Never mind, it matches. Note that finding the magnitude of ##\vec A + \vec B + \vec C## is 260 is not enough to ensure ##\vec R = \vec A + \vec B + \vec C##; the direction has to be the same too.
But from you answer I expect you did the right thing and equated x and y components. WEll done.
Hi, I am a newbie here... can someone explain how did he got the values of B and C??
how did you got B and C??
12K
10K
10K
