Finding a linear transformation.
The discussion revolves around finding a linear transformation T: R^3 -> R_1[x] with a specified kernel. Participants explore the implications of the kernel being spanned by vectors (1,0,1) and (2,-1,1), leading to a dimensional analysis that suggests the image of T must be one-dimensional. There is confusion regarding the representation of the transformation and the relationship between the coefficients in the transformation matrix. Ultimately, the goal is to express T in a form that maps vectors in R^3 to a polynomial in R_1[x], with a focus on providing a specific transformation rather than a general case. The conversation highlights the need for clarity in defining the transformation and its representation.
peripatein
Hi,
How may I find (or prove that there isn't) a linear transformation which satisfies T: R3->R1[x], ker T = Sp{(1,0,1), (2,-1,1)}?
I am not sure how to approach this. I understand that kerT is the group of all vectors (x,y,z) in R3 so that T(x,y,z) = 0 = Sp{(1,0,1), (2,-1,1)}. So x = alpha, y = -beta, z = alpha + beta? Hence, x,y,z=0? Hence, T has to be one-to-one? Since dim(R1[x]) is 2, does that mean that there is no such linear transformation?
I don't understand what you try to do with your alpha and beta.
Every vector which can be written in that way is part of ker T - and now? What about vectors which cannot be written like that?
You can use a dimensional analysis to prove that there is no surjective linear transformation (with the given ker T), but that is not relevant here.
Won't dimensional analysis show that dimIm(T) must be equal to 1? How does that help me disprove that no such linear transformation exists?
Why do you think you can disprove it at all?
dim Im(T)=1, I agree
I don't know, wrong inference from your previous post I presume. In any case, how shall I proceed?
R_1[x] is the set of all polynomials of the form ax+ b for real numbers a and b (unless I am misunderstanding- I would call that R[x] without the "1"). We can represent that by the column vector \begin{bmatrix}a \\ b \end{bmatrix} and so we can represent a linear transformation from R^3 to R_1[x] by a 3 by 2 matrix:
\begin{bmatrix}a & b & c \\ d & e & f \end{bmatrix}\begin{bmatrix}x \\ y \\ z \end{bmatrix}= \begin{bmatrix}p \\ q\end{bmatrix}
Saying that the kernel is spanned by (1, 0, 1) and (2, -1, 1) means that
\begin{bmatrix}a & b & c \\ d & e & f \end{bmatrix}\begin{bmatrix}1 \\ 0 \\ 1 \end{bmatrix}= \begin{bmatrix}a+ c \\ d+ e\end{bmatrix}= \begin{bmatrix}0 \\ 0 \end{bmatrix}
and
\begin{bmatrix}a & b & c \\ d & e & f \end{bmatrix}\begin{bmatrix}2 \\ -1\\ 1\end{bmatrix}= \begin{bmatrix}2a- b+ c \\ 2d- e+ f\end{bmatrix}= \begin{bmatrix}0 \\ 0 \end{bmatrix}
So we must have a+ c= 0, d+ e= 0, 2a- b+ c= 0, and 2d- e+ f= 0. That gives four equations with which we can solve for four of a, b, c, d, e, and f in terms of the other two.
Would you care to explain the logic behind such approach? For instance, why did you choose a matrix whose first two elements in the first row are the elements of the column vector [a,b]?
a to f are just some constants (with arbitrary names), as this 2x3-matrix represents an arbitrary linear transformation from R^3 to R^2 (or R[x] in this special case).
Right, but it is for a reason that a and b appear in both cases, namely first two elements in the first row of the matrix AND the elements of the column vector [a,b]. I am asking why is that.
Moreover, I have a general question - are all different bases linearly dependent?
No, they are not related. As you can see, HallsofIvy replaced the names by p and q in the first equation to avoid collisions.
Okay. The result I obtained was a=b=-c and d=-e=-f/3.
How do I derive my answer from these values?
As you have no additional restrictions, you can choose two values for those parts to find a linear transformation.
a=b=-c=5, d=e=-f/3=7 for example.
Hence, how should the final answer be presented? Shouldn't it be presented in the form of a polynomial ax+b?
The final answer should give some unique way to map all vectors (g,h,i) to vectors px+q.
In that case, I don't think I understand. I thought I was to provide a general term for a transformation answering the criteria as presented in the question. Would you clarify, please?
You have to give a single linear transformation - this is a specific way to map every vector of R^3 to a polynomial: Like an equation T(g,h,i)=... which can be used for all values of g,h,i and gives a result which depends on g,h,i.
Let me see if I got it correctly. Supposing I take the values for a,b,c,d,e and f, and substitute them into the original matrix as suggested by HallsofIvy, I get a single column vector whose elements are 5x+5y-5z and 7x+7y-21z. To what end does that serve me?
  • · Replies 26 ·
