How Do You Find a Local Inertial Frame for a Given Metric?
The discussion focuses on finding a local inertial frame for the metric ds^2 = -(1+Φ(x))dt^2 + (1-Φ(x))dx^2. The user successfully transforms the metric to match the Minkowski form at a specific point but struggles to make the first derivatives with respect to the transformed coordinates vanish. They explore a coordinate transformation involving arbitrary velocity and specific scaling factors but find that the derivative does not simplify as expected. Questions arise about whether the transformed coordinates represent geodesics and whether a different choice of coordinates centered on the point of interest might yield better results. The conversation emphasizes the complexities of achieving a local inertial frame in curved spacetime metrics.
PeroK
Insights Author
2024 Award
I am trying to find a local inertial frame for the following metric:
ds^2 = -(1+\Phi(x))dt^2 + (1-\Phi(x))dx^2
I can get the transformed metric to equate to η at any point, but I can't get the first derivates wrt the transformed coordinates to vanish.
Co-ordinate transformations.
With a transformation of the form:
##t = \frac{\gamma}{a}(t' + vx') \ , \ x = \frac{\gamma}{b}(vt' + x')##
And setting ##a= \frac{1}{\sqrt{1+\Phi(x_p)}}## and ##b= \frac{1}{\sqrt{1-\Phi(x_p)}}## for a particular point ##x_p## I get
##g'_{αβ} = η## as required
I've got my one degree of freedom, in terms of the arbitrary velocity ##v## to try to make the first derivative of ##g'## wrt ##x'## vanish. But, for example, I get:
##g'_{00} = \gamma^2(-\frac{(1+\Phi(x))}{a^2} + \frac{v^2(1-\Phi(x))}{b^2})##
Giving:
##\frac{\partial g'_{00}}{\partial x' } = - \frac{\gamma^3}{b} \Phi '(x) (\frac{1}{a^2} + \frac{v^2}{b^2})##
Which is not going away. The general argument is that one can always find ccordinates where all the first derivates vanish, but I don't see it in this case.
This was an example I set myself to try to see how the general process of finding a local IRF worked.
Are your primed coordinate curves geodesics? For example, if ##x_p## is the event labeled by ##\left( x' , t' \right) = \left( 0 , 0 \right)##, are the curves ##t' = 0## and ##x' = 0## geodesics?
The primed co-ordinates have the same origin as the unprimed. Should I look instead at primed co-ordinates centred on ##x_p##?
  • · Replies 0 ·
