Finding a Polynomial with Nonnegative Coefficients
11 replies · 3K views
chillfactor
find a polynomial P(x) which has nonnegative coefficients. If P(1)=1 and P(5)= 426, then wast is p(3)
P(1)= 6
P(5)= 426
P(3)= x
I have tried to use guess and check. I can't find a way to solve algebraically.
There is no specified degree for p(X). It just has to have nonnegative coefficents
Then it is best to choose a degree and work with that.
There is only one polynomial that works. One hint I received was that it had to be less than 6.
I have no idea how to approach it either. Can't quite gather what to do with the fact that all the coefficients aren't negative. Either way, it must be at least a polynomial of degree 4. But what suggests that it must be less than 6?
If you try to fit for example a quadratic
[tex]ax^2+bx+c[/tex] to the conditions, then you get two conditions:
a+b+c=1
25a+5b+c=426
We can subtract one from the other to get
24a+4b=425
Now we know that a+b+c=1 must be satisfied, with all non-negative numbers, so none of a, b or c can be larger than 1. That's clearly not possible if 24a+4b=425. A similar argument kills cubic polynomials
i am afraid i made a mistake when I posted the question. Actually P(1)= 6. So, could you try again. I would appreciate it.
There are lots of choices of polynomials actually, just consider a degree n polynomial of the form axn+b. We know that a+b=6, and that 5na+b=426. Two equations, two unknowns, start trying to find solutions!
If you know a little linear algebra/convex geometry there's a neat explanation for how you can decide exactly which coefficients are able to be non-zero
welcome to pf!
hi chillfactor! welcome to pf! :wink:
chillfactor said:
find a polynomial P(x) which has nonnegative coefficients. If P(1)=6 and P(5)= 426, then wast is p(3)
i assume all the coefficients must be whole numbers?
then ∑an = 6 and ∑an5n = 426
obviously a0 = 1,
and by subtracting we have 4a1 + 24a2 + 124a3 = 420 …
carry on from there :smile:
