Finding a Solution for a Differential System with Initial Conditions
8 replies · 2K views
skrat
Find a solution of the system ##{x}'''=2x+y## and ##{y}'''=x+2y## for which ##x(0)={x}'(0)=0## and ##{x}''(0)=1## also for ##y(0)={y}'(0)=0## and ##{y}''(0)=1##.
I must be doing something wrong:
##\begin{bmatrix}
{x}'''\\
{y}'''
\end{bmatrix}=\begin{bmatrix}
2 & 1\\
1&2
\end{bmatrix}\begin{bmatrix}
x\\
y
\end{bmatrix}##
Eigenvalues are ##\lambda _1=1## and ##\lambda _2=3## so eigenvectors ##v_1=(-1,1)## and ##v_2=(1,1)##.
Therefore matrix ##D=\begin{bmatrix}
1 & 0\\
0& 3
\end{bmatrix}## and matrix ##P=\begin{bmatrix}
-1 & 1\\
1&1
\end{bmatrix}##
So general solution should be ##\begin{bmatrix}
x\\
y
\end{bmatrix}=Pe^{Dx}\vec{c}=\begin{bmatrix}
-1 & 1\\
1&1
e^x & 0\\
0& e^{3x}
A\\
B
\end{bmatrix}##
But all these conditions ##x(0)={x}'(0)=0## and ##{x}''(0)=1## also for ##y(0)={y}'(0)=0## and ##{y}''(0)=1##... What do I do? :/
Thank you for your help!
##\begin{bmatrix}
{x}'''\\
{y}'''
2 & 1\\
1&2
x\\
y
\end{bmatrix}##
1 & 0\\
0& 3
-1 & 1\\
1&1
\end{bmatrix}##
x\\
y
-1 & 1\\
1&1
e^x & 0\\
0& e^{3x}
A\\
B
\end{bmatrix}##
λ2 is not 3, but third root of 3. Both x and y are functions of the same variable, say t. And you tried to find the solutions as x(t)=aeλt and y(t)=beλt. You cannot write exponents of x into the solution.
What does the last matrix equation mean for x(t) and y(t)? ( Expand the product.) You have to find the constants A and B so as the initial conditions are fulfilled.
ehild
##det\begin{bmatrix}
2-\lambda &1 \\
1 & 2-\lambda
\end{bmatrix}=(2-\lambda )^2-1=\lambda ^2-4\lambda +3=(\lambda -1)(\lambda -3)=0## ?
am... it means that ##\begin{bmatrix}
x\\
y
-Ae^x+Be^{3x}\\
Ae^x+Be^{3x}
\end{bmatrix}## but i have 6 conditions for only two constants... O.o
It is not a first order but third order system of equations. And your matrix equation means that x= -Aex+Be3x. Do you think it true? ehild
Am, I can see the problem but I have to admit that I don't know what to do? Should I calculate the eigen values of matrix ##A^3## ?
Uf, good point, I guess the ##'## mean derivation by t and not by x.
No, why ? Still, yo can assume the solutions of form x=aeλt, y=beλt). Substitute into the original equations. You get values 1 and 3 for λ3. But λ is a complex number, and you have the complex third roots, 6 values altogether.
Or you can introduce dummy variables u=dx/dt, v=du/dt and p=dy/dt, q=dp/dt to transform the original equations into first order ones. Then you have a system of six first order equations and you can solve it with the standard method.
ehild
Aaa, ok, i get it now... Is this a standard procedure for systems that are second orders or higher?
So I will get a polynomial ##\lambda ^6-4\lambda ^3+3=(\lambda -1)(\lambda ^3-3)(\lambda ^2+\lambda +1)##
This gives me ##\lambda _1=1## and ##\lambda _{1,2}=\frac{1}{2}(-1\pm i\sqrt{3})## and ##\lambda _3= \sqrt[3]{3}##
How exactly do I get the other two? O.o
λ6-4λ3+3=0 is a quadratic equation in λ3, with solutions λ3=1 and λ3=3.
So the roots are 1, (-1/2±√3/2 i) and 31/3, 31/3(-1/2±√3/2 i)
(You can factorize λ3-3 in the same way you did with λ3. If a=31/3, λ3-3=(λ-a)(λ2+aλ+a2).)
ehild
