Finding a substitution to solve y'=(y-x)²
17 replies · 2K views
Lindsayyyy
Hi
[tex]y'=(y-x)^{2}[/tex]
I have nearly no idea in order to solve this solution. One hint is given: We shall find a new variable which makes it possible to separate the differential equation afterwards.
I'm not sure what's meant by "new variable". Shall I just find something cmpletly new, like let's call it z, or an addition like +x or *x etc.(just for example, I know this specific example doesn't work)?
Thank you for your help
First thing I can suggest is posting this in the right place. Differential equations are definitely NOT precalculus
Lindsayyyy said:
Hi
Have you studied homogeneous functions? Your right side is homogeneous of degree 2 so try changing the dependent variable from y to u by y = ux.
[Edit:] Never mind this suggestion. When the equation is put in the form Mdx + Ndy = 0 not both M and N are homogeneous.
Since it is the fact that it is y- x that is squared and not just x or y that is the problem, let z= y- x. Then z'= y'- 1 so that y'= z'+ 1= z^2. z'= z^2- 1.
When you get the answer, make sure you check it by taking the derivative - it's really cool how it works out! :)
do the subst:
[tex] z(x) = y(x) - x[/tex]
Then the variables in the new equation can be separated.
I'm still unsure.
I tried the following, I took the substition from HallsofIvy
[tex]y'=z^{2}-1[/tex]
Shall I just integrate both sides now? I think this doesn't work, as I still have y and x after the integration on one side.
And I wonder about the following:
I have [tex]y'=z^{2}-1[/tex] but when I say I substitute [tex]x-y=z[/tex] and insert it in my given equation I have [tex]y'=z^{2}[/tex] :mad:
I think you misunderstood. The equation HallsofIvy got to is
[tex]z' = z^2 - 1[/tex]
Not y'.
You performed the substitution incorrectly. If z = y - x, take d/dx of both sides: dz/dx = dy/dx - 1. Since dy/dx = (y - x)^2 = z^2, we have dz/dx = z^2 - 1.
Now, separate variables and use partial fractions. To separate variables, integrate both sides of f(z) dz = g(x) dx. :)
Thank you, just to make sure I didn't do any mistakes thus far. I have to do the partial fraction with the following:
[tex]x= \int \frac1 {z^{2}-1} dz[/tex]
Yes. For simplicity's sake, I'd put your constant of integration (+ C) on the x side.
Wow, it's really embarrassing right now.
My partial fraction looks like:
[tex]\frac 1 {z^{2}-1} = \frac A {z-1} + \frac B {z+1}[/tex]
[tex] A= \frac 1 2[/tex]
[tex] B= -\frac1 2<br /> [/tex]
Now I tried to integrate
[tex] <br /> x=\frac1 2 \int{\frac 1 {z-1}}dz - \frac 1 2 \int{\frac 1 {z+1}}dz[/tex]
getting:
[tex]2x+2c = ln(z-1)-ln(z+1)[/tex]
but the z gets lost when I *exp on both sides. Where's my mistake. It's so frustrating :cry:
Don't fret. Recall that ln(a) + ln(b) = ln(ab) and ln(a) - ln(b) = ln(a/b).
Also, when you take the exponential of 2x + 2C, let A = e^(2C) for simplicity. Your left side should be Ae^(2x).
Thanks for the help and patience :biggrin:
my solution looks like this:
I used the ln calculation rule:
whereas, as you said, my A=exp(2c)
[tex]z=\frac {1-A-e^{2x}} {-1+A+e^{2x}}[/tex]
the only step I have to do now is to resubstitute z with [tex]z= x-y[/tex]
and solve the equation, bringing y on one side, which would look like this:
[tex]y=\frac {-1+A+e^{2x}} {1-A-e^{2x}} +x[/tex]
is this correct (and the final answer) ?
No, but close. For any base k > 0, k^(a + b) does not equal k^a + k^b; it equals (k^a)(k^b).
Also, we set z = y - x, not z = x - y.
I should really try to concentrate some more :smile:
Another attempt, A=exp(2c) like before
final equation looks like:
[tex]y =\frac{-1-Ae^{2x}} {-1+Ae^{2x}}+x[/tex]
Yes! Well done. One more thing: you could decimate the abundance of minus signs (*shudder*) by multiplying with -1/-1 to get
[tex]y = \frac{1 + Ae^{2x}}{1 - Ae^{2x}} + x[/tex]
as your final answer.
As an exercise, you should find y' and see that it does indeed equal (y - x)2. See post #5 :)
Thank you very much :smile:
I'll try that, I tried it for the specific A=0 because that worked quite fast, but I'll do it generally and see how it works. I really need some practice with differential equations.
