Finding acceleration and maximum displacement from Vx = 2.0t - t²
9 replies · 5K views · last reply
ldesai149
The velocity of an object moving along the x-axis is given by Vx = (2.0t-t2)m/s. Initially (at t=0), the object was at the origin.
a) Determine the object's acceleration at t=3.0s.
b) Find the object's position at t=3.0s
c) Calculate the object's maximum positive displacement from the origin.
a = dv/dt
xf = xi + vxit + (1/2)axt2
vxf2 = vxi2 + 2ax
[/B]
a) To get an equation for acceleration,
ax = dv/dt = d/dt (2.0-2t)
= 2.0 - 2(3.0s)
= -4.0 m/s2
b) xf = xi + vxit + 1/2axt2
= (0 m) + (0 m/s)(3.0 s) + 1/2 (-4.0 m/s2)(3.0s)2
= -18.0 m
c) delta x = [vxf2 - vxi2] / [2ax]
= [2.0 (3.0s) - (3.0s)2]2 - [0 m/s] / [2 (-4.0 m/s2)]
= -1.1 m
First of all, I'm not sure if I've done the derivation for the acceleration equation correctly. Also, question c) asks for maximum POSITIVE displacement but I keep getting a negative value. I'm not sure where I'm going wrong!
For (b) and (c) you are using "constant acceleration" equations. Is the acceleration of this object constant?
The question doesn't say either way... I get the feeling I'm missing something but I don't know what.
Use the given expression for the velocity as a function of time to decide if the acceleration is constant.
Ok, so if I plug in different values for t in acceleration equation, the values are not constant... The only solution I can think of is to calculate x separately for each second? Also, am I correct in assuming that my answer for b) is still accurate since I calculated acceleration for the same time (t=3.0s)?
Thank you for all your help! (I'm a healthcare student who's forgotten all her high school physics...)
Right.
Can you derive the position vs time function x(t) from the velocity vs time v(t)? What calculus operation should you use to do this?
Alright, so I integrated v(t) to get x(t) = -1/3t3 + t2 + C.
Input values of t=1,2,3,4 and found that at t=2.0s, the positive displacement is 1.33m, at t=3, it is 0m and at t=4, it is -5.3m.
So, the maximum positive displacement is 1.33m at t=2.0s.
Have I finally got it right?
OK. But what is the value of C?
Yes, at t = 3.0 s, the object is at x = 0.
For part (c), how do you know that the maximum positive value of x will occur for an integer value of t?
When I solve for C:
From b), I have x(t) for t=3.0s is -18.0m
x(3) = -18.0 = (3)2 - (1/3)(3)3 + C
-18.0 = C
But that doesn't seem right.
In your first post, you didn't get the correct answer for (b) because you assumed that the acceleration is constant.
You can determine the value of C by using the information given in the problem statement about the location of the object at t = 0.
