Finding acceleration as a function of time given acceleration vs position
  • Level: Undergrad
  • Thread starter Thread starter NJJ289
2 replies · 2K views
NJJ289
Given the acceleration of a particle as a function of its position (x) along a straight line, how can one create a function to represent its acceleration as a function of time (t)?
I haven't covered differential equations yet and was wondering if this is an example of a kind of problem that subject deals with.
For example,
Let's say the particle moves with A(x)=M/X^2
taking d(A)/d(x) can give the change in Acceleration at any distance x, but what about time?
In calc 1 we did some 'related rates' problems that were similar to this, but they always had a special relationship that let you solve it (right triangles etc).
So: how do you solve this case in particular, what subject matter deals with this, and where can I get more info on other questions like it?
Thanks for the help! :)
Typically what happens is that you parametrize the system.
I'll give an example of a something going in a circle.
Say we have a system x^2 + y^2 = 1.
We can use the substitution
x = cos(theta)
y = sin(theta)
Now using trigonometric identities we can verify this works since
x^2 + y^2 = cos^2(theta) + sin^2(theta) = 1 as required.
You basically do the same sort of thing and put things in terms of a parameter (namely time), but its not always easy to do so (as the circle example)
For example,
A is the velocity at position x? Then the "acceleration" is the derivative with respect to t, not x, whether at a given x or t. Using the chain rule, the acceleration would be given by
[tex]\frac{dA}{dt}= \frac{dA}{dx}\frac{dx}{dt}[/tex]
Now, since A is velocity, you are saying that [itex]dx/dt= A[/itex]
so that equation would be the same as
[tex]\frac{dA}{dt}= A\frac{dA}{dx}[/tex]
In particular, if A(x)= M/x^2, as you give, then
[tex]\frac{dA}{dt}= \left(\frac{M}{x^2}\right\left(\frac{-3M}{x^3}\)= -\frac{3M}{x^5}[/tex]
That's just Calculus- in particular the application of the chain rule.
