Finding Acceleration from Friction Coefficient and Force Applied
The problem involves determining the acceleration of a crate being pushed across a rough floor, taking into account the applied force, the angle of application, the mass of the crate, and the coefficient of kinetic friction.
  • Participants discuss the calculation of frictional force and the normal reaction force, questioning whether the normal force is simply mass times gravity or if it should include the vertical component of the applied force.
The discussion has progressed with participants providing guidance on how to correctly calculate the normal force and frictional force. There is an acknowledgment of differing interpretations regarding the components of the forces involved.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is a focus on ensuring the correct application of physics principles without providing direct solutions.
ChrisMihm31
To move a large crate across a rough floor, you push on it with a force F at an angle of 21°, below the horizontal, as shown in Figure 6-21. Find the acceleration of the crate, given that the mass of the crate is m = 32 kg, the applied force is 344 N and the coefficient of kinetic friction between the crate and the floor is 0.54.
http://www.webassign.net/walker/06-16alt.gif
a = Fnet/m
Ffriction = Fnormal * muk
First I found the frictional force by (.54)(32 kg)(9.81 m/s2) = 169.5168
Now this is where I am stuck. Do you subtract that from the horizontal force? The horizontal force I got was 344Cos(21) = 321.15. Then I do 321.15 - 169.5168 = 151.63 and then divide that by the mass(32kg) and get 4.74
This is obviouley what you aren't supposed to do, so HELP!
Sorry but your frictional force is wrong.
Force due to friction is the coefficient of friction multiplied by the normal reaction force.
First you must find the normal reaction force.
Isn't the normal force just mass x gravity?
No, because there is also a vertical component of the force applied by the worker.
Sum up the forces in the y plane to find the normal reaction force.
so would the normal reaction force be: mg + Fsin(21) ?
probably wrong, but its my best guess
That's correct.
Thanks for your help, I plugged everything in and got the correct answer: 2.66 m/s2.
