Finding angles of nodal lines in two-point source interference
benca
A two-point source operates at a frequency of 1.0 Hz to produce an interference pattern in a ripple tank. The sources are 2.5 cm apart and the wavelength of the waves is 1.2 cm.
Calculate the angles at which the nodal lines in the pattern are located far from the sources. (Assume the angles are measured from the central line of the pattern.)
λ = (xn/L)[d/(n - 0.5)]
dsinθn= (n - 0.5)λ
xn = perpendicular distance from the right bisector t o the point Pn on the nodal line
L = distance from midpoint between the two sources to the point Pn
n = number of the nodal line
d= separation of the sources
I'm having trouble understanding what it's asking me. "Calculate the angles at which the nodal lines in the pattern are located far from the sources." I assume they are very far away, making lines PnS1 and PnC parallel. Is the question asking me to calculate θ' in the example?
"nodal lines" should I solve for several different values of n? I was thinking of using dsinθn= (n - 0.5)λ to solve for θn since θn = θ' If that's right, for how many nodal lines do I do this? Also why would they provide the frequency? Attached in a diagram from a previous example.
Geometry diagram of two point sources S1 and S2 separated by distance d, with a perpendicular bisector through midpoint C, a distant point Pn at top right, path length L, and angles theta-n and theta-n prime marked.
So I used dsinθn= (n - 0.5)λ to solve for the first two nodal lines and got 13.8° for the first and 46° for the second. When I tried to to input 3 for n I got a domain error. Does that mean the third nodal line is greater than 90° and didn't strike the screen?
I also still don't know the reason why frequency is provided.
What do you think? Calculate sinθ3 and see what you get.
I don't know either.
