Finding Basis for Subspaces of R4
  • Thread starter Thread starter Dell
    Basis Subspaces
Dell
i am given 2 subspaces of R4
W=sp{(a-b,a+2b,a,b)|a,b\inR}
U=sp{(1,0,1,1)(-6,8,-3,-2)}
and am asked to find:
a homogenic system for W- system for a vector (x,y,z,t) belonging to W
i see the basis for W is : a(1,1,1,0)+b(-1,2,0,1),, i put these vectors into an extended matrix with (x y z t) on the other side, and after a series of elementary operations, i get
x+t-z=0
y-z-2t=0
next i am asked to find
a basis for W+U and W\capU
forW\capU
i find a homogenic system for U, and compre it with the system i found for W which comes to
x+t-z=0
y-z-2t=0
y+8z-8t=0
3t-4z+x=0
and i come to
t=1.5z
z=z
y=4z
x=-0.5z
so for W\capU i get a basis (-0.5, 4, 1, 1.5)
for W+U i take the basis of each and check independace of all of them together, in which i get that all4 are independant, therefore the basis for W+U={(1,0,1,1)(-6,8,-3,-2)(1,1,1,0)(-1,2,0,1),}
if i perform elementary colum operations on them i can get to (1000)(0100)(0010)(0001), doesn't this mean that W+U is the whole vector space R4 ??
the final question is
find a vector other than the zero vector which is orthagonal to all the vectors in U+W
is this possible, since i found that W+U is the whole vector space R4 (supposing i was correct there)??
Yes it does. In fact a certain theorem tells you that if you can find a set of n linearly independent vectors spanning R^n then that set is a basis for R^n. EDIT: I just checked it and I realized that the vectors are in fact not linearly independent. You need to re-check that part.
EDIT: As above the vectors are not linearly independent.
If W \cap U \neq {0} then the set {basis of U} \cup {basis of W} must be linearly dependent.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
