Finding Centroid of Triangle in First Quadrant
  • Thread starter Thread starter magma_saber
    Centroid
4 replies · 2K views
magma_saber
Find the centroid of the triangular region in the first quadrant bounded by the line 4x+y=4, the x-axis, and the y-axis.
[tex]\int[/tex][tex]\int\delta[/tex]dA
xbar = My/M
ybar = Mx/M
Is the boundary for the dy from 0 to 4, and dx from 0 to 4-4x?
so its y-4/4?
also are my limits for dy correct?
No, that's not quite correct either. (I assume you mean (y-4)/4, not y-1.) You should always plug in a few values to do a sanity check. In this case, when y=0, you'd get a negative answer.
Your limits for y are fine. (But I'll note I'm saying this under the assumption that you set things up correctly.)
Did you draw a sketch of the region of integration?
the region would be the triangle from y=4 to y=0 and x=0 and x=1 right?
and is the limit 4-4x?
