Finding constants of a quartic equation
  • Thread starter Thread starter chwala
    Constants
9 replies · 2K views
chwala
The polynomial ##4x^4+Ax^2+11x+b## where ##a## and ##b## are constants, is denoted by ##p(x)##. It is given that ##p(x)## is divisible by ##x^2-x+2##. Find the values of ##a## and ##b##
factor theorem
##4x^4+Ax^2+11x+b##≡##(x^2-x+2)(ax^2+mx+d)##
≡##ax^4+(m-a)x^3+(d-m+2a)x^2+(2m-d)x+2d##
##a=4##
##m-a=0, m=4##
##d-m+2a=A##
##2m-d=11##
##2d=b##
##A=1##, ## B=-6 ## is that correct?
chwala said:
Homework Statement:: The polynomial ##4x^4+Ax^2+11x+b## where ##a## and ##b## are constants, is denoted by ##p(x)##. It is given that ##p(x)## is divisible by ##x^2-x+2##. Find the values of ##a## and ##b##
Relevant Equations:: factor theorem
##a=4##
##m-a=0, m=4##
##d-m+2a=A##
##2m-d=11##
##2d=b##
Yes.
@chwala :
Try to be consistent with labeling of parameters.
In the given quartic polynomial,you use ##A## and ##b##. The question then asks for values of ##a## and ##b##. Then in the unknown quadratic factor, you use ##a## which is all together different from previous ##a## or ##A##, although, by inspection you can determine that this ##a=4## .
In the answer, you have ##A## and ##B##.
That was a pretty easy question...i guess i was just over thinking on it... :biggrin: :cool:
SammyS said:
@chwala :
true, i had seen that but i just ignored ...noted
(Using uppercase ##A## and ##B## for the problem), I suppose you could say, if ##x^2-x+2## is a factor of ##4x^4+Ax^2-11x+B##, then by inspection, the other factor must be of the form ##4x^2+mx+\frac B 2 ##.
Multiplying the quadratics gives:
##\left(x^2-x+2\right) \left(4x^2+mx+\frac B 2 \right) = 4x^4+(m-4)x^3+\left(8-m+\frac B 2 \right)x^2 +\left(2m-\frac B 2\right)x +B##.
Match coefficients.
etc.
##a=4##
##m-a=0, m=4##
##d-m+2a=A##
##2m-d=11##
##2d=b##
Not sure it's any easier, but another method is to use ##x^2=x-2## to substitute for ##x^2##, first in the ##x^4## term, then in the resulting ##x^2## term.
The resulting linear expression must equal zero.
i do not get this approach ##x^2=x-2## how? from where...
aaaaaah...seen that..thanks haruspex
