Finding current, voltage and power across RL using Norton's theorem
  • Thread starter Thread starter amy_a
    Theorem
6 replies · 6K views · last reply
amy_a
hi guys, sorry to be a bothersome newbie but i have another electrical query. this time its nortons theorem. i need to determine the current through RL, the voltage across RL and the power developed in RL using the theorem.
any pointers on where to start would be really appreciated :!)
R(Norton) = R (Thevenin).
I(Norton) = [E/(R1+(R2//R3))]*[(R2//R3)/R3]
Regards,
Nacer.
ok forgive my naivety but what do the double backslashes indicate? // like that? i know the single one is divide. i feel really retarded now.
I think he is referring to a parallel combination, i.e R1//R2 = (R1*R2)/(R1+R2)
Norton equivalent is no different from Thevenin. Norton equi. = Current Source with a resistor in parallel and Thevenin has voltage source and resistor in series. So, basically you can apply your knowledge of Thevenin equivalents from antoher thread :biggrin: and then just replace a thevenin equ that you'll get with Nortons
thanks guys :) i appreciate it! can anyone tell me why r4 is not considered when calculating the current (using the equation given by nacer) would i just have to apply that formula to the diagram above to find the norton current?
Every resistor excluding Rl&R4 has to be considered, because you're looking for so-called short-circuit current, so when you have a direct connection between the RL terminals, where does the current go? Since the current is looking for the easiest path, the path with least resistance, it will go just via a direct connection, rather then going via R4.
Check out this link to get more info.
http://en.wikipedia.org/wiki/Norton's_theorem
I suggest that you read up on the Nortons procedure.
1. Calculate the short-circuit current by applying the direct connection between output terminals
2. Calculate output resistance by replacing the voltage source with a short-circuit
3. Norton-source = short-circuit current & Output resistance = resistance from step 2.
